Wiper Fluid - anemic spraying / weak spray?
hgpilot
Matt
Chattanooga, TN
CyberTruck Foundation
VP
Not sure if this is just my CT but when I need to use washer fluid on this giant beautiful windshield - I get marginal results. While I love the staggered spray pattern (great design) there just isn't enough fluid spraying out to do the job without streaking. Fluid levels are full, spray system seems to be working fine - but just isn't enough solution coming out. System isn't clogged - anyone else have this issue?
Brandon708
Brandon
Downers Grove, IL
oneupsigns.com
Cybertruck, GMC Seirra, Model X, E-Transit, F550
Sign maker
I agree. I am not happy with the wiper and how it distributes the fluid. It doesn't put enough on the windshield. I want to soak the windshield with fluid then wipe. I feel the fluid doens't have enough time to soak into the dirt then have a clean wipe. It wipes it off to quick then leaves streaks. It also wipes a last dry wipe without fluid and causes streaks. I cringe every time it does that last dry wipe.
Macgreiner
Mac
Maryland
i3 (sold), S70D(sold), R1200RT, LR3, P3D, MYAWD
Global Operations
You may want to check, but I believe this is a recall on this.
Bumn
Laurence
Boca Raton
same here, I think the issue is the fluid sprays almost on the wiper blade, so you do not even see the windshield get really wet, I usually hit the washer like 5x, it works but yes, it is weak
vinsk
Vin
FL
MYP, Cybertruck FS AWD
SW
Same here! Mercedes had this design many years ago called "Magic Vision Control", used to work pretty great on my GLS. Can't say the same about CT, leaves a lot of streaks.
Mine hasn't changed since it was delivered in April. I need to hold down the spray button too long. It seems like it would clean better if it pumped fluid on the backstroke instead of right in front of the wiper. This could be accomplished with an Over-the-Air update. But maybe Tesla is concerned that leaving too much unwiped fluid on the windshield (until the wiper returns) is a visibility hazard.
It works best in the rain, not so much to clean a dry windshield.
MilliVanilli
DMV
S
Agreed. Maybe they could have this different behavior when the car is stationary.
Nurkbonis
Ya, it’s bad. I asked the service center about it and they told me the performance of my wiper spray is consistent with other Cybertrucks…
Hopefully there is a recall or fix for this.
I could live with it the way it is but, I agree, a fix would be nice. It's the worst thing about a truck that comes closer to perfect than any other truck/suv on the market.
Brandon708
Brandon
Downers Grove, IL
oneupsigns.com
Sign maker
Mine seems to have less pressure than it previously had.
At be the new update changed the pressure?
