Cirrus SR22
After getting the CT on Wednesday, I can say the range is as advertised or better. Wh/m since my last charge and after driving nearly 200 miles of freeway/streets with 2000 foot Gaines on a 45 mile leg on the freeway and back down.
This works out to 328 miles for a full pack which is more than advertised. The aero covers should improve a bit.
Although I drove 65-70 on freeway and speed limit on streets, energy management is key. For example, on a long down hill I coast by not regenerating nor using any power. If you see the green bar, you are regenerating. Press the power pedal slightly to remove regen. If you see the gray power bar go up, you pressed too far and are now using power. Sometimes going faster downhill will increase range because you stop regen and coast as long as you stay within the speed limit. Of course if speed picks up too much you must lift and start regen. Understanding the energy management is key for long range. I call this the Scott Dixon approach, if you follow Indy Car racing you will understand.
Tesla Cybertruck Awesome range when practicing energy management -- range is as advertised or better in my Cybertruck IMG_5964
jasper7821
Ken
Tesla M3, Jaguar F-Type, Porsche Macan GTS, Indian
Aircraft researcher
After getting the CT on Wednesday, I can say the range is as advertised or better. Wh/m since my last charge and after driving nearly 200 miles of freeway/streets with 2000 foot Gaines on a 45 mile leg on the freeway and back.
Great to hear the truck is giving you decent watts per mile.
Cool. Thanks for posting to offset all the other negative crap out there! It’s good to see range can be as advertised. Other posts have gotten close, but not as high as you appear to have done.
Yeah, most of the early tests were done at high speed with plenty of launches and braking thrown in for good measure (and probably with tires not inflated ideally). No car and especially no truck, is going to get it's EPA combined Hwy/City rated efficiency at high speed with people amped up on having one of the first Cybertrucks. Slow down a bit, run proper pressures, and you will go a lot further. It should improve a bit more when the aero wheel covers come back.
I'm jealous, enjoy your ride!
Gundo
Gundo
Connecticut
Porsche C2S
Thanks for this! Didn't actually know that you can turn off regen going downhill with a throttle blip - will have to try that in my '23 MY LR Nice to have some positive comments, especially with all the FUD being thrown around
Cyberostachu
Manny
Nevada
I've not received my CT yet but my question is, in a long downhill, why would I choose to not regen
I like your post but my question is, when going on a long downhill, why would I remove the regen? I thought that's the chance to recoup some energy lost.
Thanks.
CyberOnSpinners
Jared
Houston, TX
Cybertruck Foundation - Cyberbeast
Engineer, self-employed
This. Does not make sense to me. Not using regen speeds you up, yes, but regen is recharging your batteries. Your argument assumes that removing regen by tapping the throttle gets you were you are going ever so slightly faster. I get that, but regen should be refilling your battery fast enough to provide enough energy to actually go FURTHER than you are getting when removing it. If you want to test, turn it all the way off and take a trip from full charge at go 100 miles. Next day, turn regen on and do your best to take the same trip with same accel/decel and you’re pretty much guaranteed to get more range while regen is IN USE.
KG206
Kevin
Maple Valley, WA
Dual motor
What’s the logic behind not using regen, which provides energy back to supply?
Are you claiming regen in fact uses power? Not my experience in Model 3, I’ve watched percentage increase coming down a mountain pass.
Cybergirl
Illinois and Arizona
This "coasting" technique is interesting. What you are claiming is that by cancelling regen on a down slope, you are covering more miles per wH of energy than by converting kinetic energy to electrical energy and reusing the electrical energy. It means that on the down slope, the speed of the vehicle increases avoiding the energy conversion loss that occurs with regen. The only problem I see is the amount of attention required of the driver to minimize the regen. It won't work using any type a ADAS, e.g., Autopilot or FSD.
HTownQ
Henry
Houston
Tesla CyberTruck
That’s a great explanation of how to manage the power/battery from the green & grey indicator on screen. My experience has been great with range in the city with highway and main roads combined.
On freeway driving all seemed good up to about 65. Here in Texas we have long stretches of roads at 75 mph speed limits. I noticed loss of range at 75-80. I do not have anything concrete but it seemed to be 100 miles used 125ish miles of battery life.
ideaXfactory
IdeaX
MO
Many trucks, and a Porsche
That speed helps carry you up the next hill... Truckers been doing that forever.
Also - in the 70's my dad used to say "drive like you have a egg between your foot and the peddle, and don't break the egg..." Then we used some math to exactly compute the mileage gained on a tank of gas - fun memory. :)
MetalBonsai
Washington
Cybertruck FS AWD, 2017 Lexus RX350
Artist
To clarify: you're being gentle with the accelerator to keep your grey 'drain' bar down. And you're staying out of 'regen' territory generally to maintain speed over long distances. Makes sense.
To maximize regen on exit ramps or steep downhills, I try to accelerate slightly (safely) while coasting to fill out the left pointing regen bar. If you coast fast enough downhill, the left bar goes into grey which I perceive as the limit of regen, so no point in going too fast.
And I try to let regen do all my breaking for me, trying to get it so it stops me slightly before where I need to stop, and I gently accelerate into the point where I stop.
Another hot tip to improve efficiency is to never let anyone else in the car. Don't get married or have kids, don't go out with friends, don't drive your mom to the airport. Just you. Other humans are a serious battery drain. ?
Cirrus SR22
On a downhill hill you ideally want to not see any of the grey bar nor green bar, that’s coasting which will maximize efficiency. It takes a very precise foot to do it but it’s a fun challenge. Not Sure why the software won’t just do this automatically as in our GLE450. The GLE450 is a mild hybrid and when driven in Economy mode the engine cuts out on a downhill and it will coast. If you tape the brakes Regen kicks in. It’s automatic, in the CT it requires skill to accomplish this manually.
