240v charging issues??
Jimmy Chacko
Jimmy
Furlong, PA 18925 USA
Tesla Y
Need help troubleshooting a charging issue with my Cybertruck's 240V bed outlet. I hooked up my Tesla charging cable to share power with my Model Y, but the Model Y
Tesla Cybertruck 240v charging issues?? 1000284516
gave me the attached error alert. Has anyone run into this problem while vehicle-to-vehicle (V2V) charging? Let me know your thoughts."đź’ˇ
Autobot
Mitch
kentucky
2024 Cybertruck Foundation Series
If your truck is suffering from the PCS2 issue, your outlets will not function. Is that possibly the case?
Try reducing the Y's charge limit to 24A or lower. That's the max output if the Cybertruck PCS is partly failed.
Autobot
Mitch
kentucky
Tesla’s Power Conversion System (PCS2) module, which contains three parallel, 16-amp charging stages (legs) to handle Level 2 home charging up to 48 amps. So it sounds like yours has partially failed (2 legs have failed). Limiting it to only 16amps. Is your home charging limited to 16amps as well?
Another PCS it looks like. Bummer
