Charging issues with CyberTruck
Celiboy
Marcel
Clovis, California
A little of column A, a little of column B ^-^
So would it be an issue in need of a software update or irrelevant because it was pulling 48/48 amps? I’ll admit my lack of knowledge in this area.
Known-Background
Pennsylvania
ModelY, Cybertruck AWD
There was that guy who drove to Oklahoma and was charging at an RV park...
Was gonna say the same thing the OK guy reported the jumping. I don’t think he showed his Amps or said they were changing.
Ri22
George
Land of Entrapment
M3 CT
Cinematographer
Curios what the infotainment screen inside the truck was displaying. Could be a glitch in the handheld app. You can easily time it to see how many mi you get over a session
ButterEV
ButterEV
Eric
www.youtube.com
You are right it could just be a bug. Either way it’ll be nice if they can send a OTA update soon just to make feel better ?
ButterEV
ButterEV
Eric
www.youtube.com
Forgive my ignorance, but you’re saying it’s a hyperactive analysis rather than a true fluctuation, am I right? If that is the case, why send that input so instantaneously as to rupture the viewers perception of charge rate? Assuming the ignorance of most owners includes a lack of understanding that the mph charge rate is irrelevant to the consistency of 48A without fluctuation. It is, after all, implemented into the app so as to be visible by the layman.
You are not wrong. Amperage is truly what matters. Not sure if Tesla wants the mi/hr to show the fluctuation or not but I found it to weird. If it’s a bug then I’m sure it’ll be fixed soon.
ButterEV
ButterEV
Eric
www.youtube.com
Good idea I’ll plug it in and see what the infotainment reads. I think I’ll also run a timed test to see what the true mi/hr rate is.
ButterEV
ButterEV
Eric
www.youtube.com
I’m curious if other owners have noticed something similar with their trucks? It’d be nice to know if it’s an every truck thing or not. Hopefully if it is a little bug it’ll get fixed soon. Great looking truck BTW.
I’m sure it’ll be fixed soon. Thanks
Pops
Houston, TX
MY, CyberBeast
I posted this on the YT video as well, but adding here for visibility. I think its just a calculation bug.
Given that the CT is likely less efficient than your Model S, I imagine it should never reach 35mph on both. Perhaps its a miscalculation and in the 20s is more correct for the CT.
48amp X 235v = 11280watts divided by 500w per mile for the CT = 22.56mph.
TeslaFANa
Fiesky
Greenville, sc
2018 model s, 2018 model x, 2024 cybertruck
Physician
Agree that the fluctuation is odd, it's good that it remains at 48 amps, it may be a software glitch like crissa says, may be that the cybertruck is cycling other software components like was mentioned here, did you notice if it stays fluctuating the whole charging session or just the first 5 - 10 minutes? Also, it would be interesting to see if that fluctuation is also seen on a third party app like Tessie (which I find helpful to analyze battery health, real battery capacity, etc).
Diveflyfish
James
Wisconsin
2024 CyberBeast 2011 BMW 335d
Dentist
Even if it were a fluctuation, it's not concerning.
The mph is based upon the Wh per mile and the remainder power after all other loads.
The charger always is fluctuating, we just usually don't see it because the software tries to take a long enough sample so the display isn't noisy.
Balancing a noisy display against getting feedback from adding load to the truck (like turning AC on or off) is a tough trick.
It is also possible that there is a differential in what the CyberTruck battery brain is requesting for charge rate or pulsing for a specific reason due to the larger surface area of the battery compared to the model s. One would have to watch this over the entire charge cycle. Pulse charge of battery to create small sharp transients may help kick the ions a bit to facilitate higher currents. https://www.ncbi.nlm.nih.gov/pmc/articles/PMC5521994/
ButterEV
ButterEV
Eric
www.youtube.com
It fluctuates throughout the charging session. I might dive deeper into this by monitoring and logging each hours true charge rate to see if it’s consistent throughout the session or if it fluctuates hour on hour.
I was unaware of the Tessie. I’ll look into this. Thanks
