This is one of my top 5 reasons why I ordered a Cybertruck. I love the 3mm thick 300 series stainless steel exoskeleton with a natural finish. It eliminates most door dings/hail damage/dents, scratched paint, pitted paint from road debris, waxing, polishing, etc. There is no other full size truck currently on the market that even comes close in exterior durability. Even the bed will be stainless steel. WOW!!!
I know, right?
Ford, GMC and Dodge have been telling us for decades how "tough" their trucks are but they've been lying through their teeth, it's just typical marketing. They are not tough unless your definition of "tough" is being clad in soft, thin, mild steel that requires a coat of paint be maintained to prevent them rusting away in a flash. Strip the paint off with an acid and the metal will rust to nothing after a couple of years in normal weather. Watch an errant baseball leave a big ugly dent. Hey, kids! Don't be playing ball around my truck because it's weak and fragile and I don't want it to get a dent. Be careful!
Let a fresh breeze cause a shopping cart to roll across the parking lot and into the side of your "tough" truck and see how tough it really is. Yes, you're going to have a new door dent. Throw a small split of firewood over the side of the bed, you had better hope your grip doesn't slip last minute causing it to bang into the side of the bed! Cause that's gonna leave a mark! Ford even makes their trucks out of softer aluminum now - they are going in the wrong direction. Yet they still call them "Ford tough".
Hailstorm? Better park that "tough" truck under a real roof. Cause those hailstones are going to leave some nice dents in that thin soft metal! Even driving down the highway small stones and pebbles will remove chips in that paint.
The Cybertruck can handle all of these threats and more without breaking a sweat. It'll be the first truck that can be honestly marketed as being "tough". Ford, GM and Dodge could learn a thing or two about what it means to be tough and powerful. They are about to be humiliated!
Cyberman
Adam
F150,F550, Escape
Cybercontractor
(Sigh) Please do just a little research before putting forth nonsensical ideas. The reason Ford has been using aluminum is they are obligated to improve mileage every few years as Uncle Sam squeezes them to improve fuel efficiency. Yes, SS is heavier, and the exoskeleton is heavy, but that extra weight is offset by not having a body-on-frame. This is the magic of the exoskeleton design, it's kinda like the frame is built into the body. This is how my dude Elon overcame the challenge to produce a badass pickup that'll last forever, without making it overly heavy. Cybertruck isn't a behemoth like the resurrected Hummer, it's in its own category, like Pink Floyd. Nothing else like it, defies classification, blows mind, will live on forever. Don't be talking trash, eh? Don't be talking trash!
Gordon E Peterson II
Gordon
Farmers Branch, TX
currently 2000 Chrysler Town & Country minivan
retired computer programmer and consultant
Wait, isn't that exactly what the 8000 ton press is for?
The 8,000 ton GIgapress is to cast (high-strength aluminum alloy) the rear suspension/chassis (and bed?). These will be the largest aluminum castings in the world.
Tesla has a very good track record of delivering the products which they demonstrate. I also know they make the most efficient cars in the industry (in terms of weight, aerodynamics, range). Munro—a respected, well known auto engineer who is not affiliated with Tesla—also suggests the exoskeleton concept is likely a huge potential weight savings.
The 3mm sides and doors are a feature of the truck every bit as much as the weight and towing capacity. Tesla wouldn’t have rolled a truck out on stage and smashed the side of it with a sledge hammer and claimed it was bullet proof if they didn’t fully expect to deliver that product to the public. They do a lot of goofy stuff and miss their projections on delivery dates, but they have to date been extremely good at delivering the product they demo.
I’m certain Tesla is going to use the lightest possible materials wherever they can possibly get away with it. But the sides, and doors, are going to be 3mm steel. The bed lining and much of the rest? I’m sure it depends entirely on whether that thickness is needed to be structural. The floor is the structural battery pack so the truck is almost certainly not going to have a layer of 3mm stainless on top of that.
In the unlikely event that Tesla ends up delivering something without 3mm stainless sides and doors, it will be shocking. I strongly suspect they would lose a lot of sales if that were the case. They made big claims about the durability of this truck and they need to follow through with them.
I pay Tesla to “do the math”, they are quite good at it.
The entire point of making the outsides of the Cybertruck out of this steel is that it increases the stiffness.
I've said it before, and I'll say it again: The Cybertruck is like a segment of a bridge. The big arches that go around a truss bridge are stronger the further out from the moment of movement. (That's usually the middle, btw)
That means that putting the structure out at the ends gives it more leverage against forces. Which means that it doesn't need as much structure inside as a typical ladder-frame truck does in the middle. So it can get away with aluminum stringers to hang the batteries, motors, and suspension, whereas the ladder-frame trucks can't. And those crossing members won't have to even be as strong as they would for other trucks. They just have to be stiff. Which aluminum and light-weight epoxies are really good at.
A uni-body (body that moves as a unit) car is much lighter for the same strength than a body-on-frame. Those ladders are just cheaper than unibody, which have to be tested and designed much more closely. This is just another step - the folded, exoskeleton unibody design.
Those super-stiff, ding-resisting sides will protect and give more strength for the buck.
Planet Earth
$59k CT delivered 6/26/26
My hunch is that the front crumple zone area will be a thinner stainless steel. Those parts include both fenders, hood and lower valance. My guess is the hood may also be scored in certain areas on the bottom side to aid in folding properly during a frontal collision.
Tesla Cybertruck 3mm thick 30X stainless steel body panels / exoskeleton 74FDB938-5CE0-4E93-8F93-1508ADBAA268
Cyberman
Adam
F150,F550, Escape
Cybercontractor
3mm is pretty damn close to 1/8"
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
I am can't wait for Sandy Monroe to perform a "tear down" video of the Cybertruck once it goes into production. I will be very interesting to say the least. I am very interested to see all of the design and engineering under the skin.
I hope Sandy is preparing well for his teardown of the Cybertruck. As excited as he sometimes gets when talking about the innovations that Tesla has made, it wouldn't surprise me if he gets so excited pulling the CT apart that he has a full-on explosion of euphoria. While I am excited to see Sandy's videos on the CT teardown, I worry for his physical and mental health if that were to happen.
LTN COLUMBO
Pierre
Ile de France FRANCE
DUSTER PRESTIGE
Comme la recette Tesla / Spacex pour leur acier inoxydable est inconnue, la résistance à la traction et au cisaillement l'est également.
La résistance estimée des panneaux Cybertruck est littéralement environ 11 fois plus résistante ou plus.
L'épaisseur des panneaux de carrosserie conventionnels varie un peu, généralement de 0,6 mm à 0,8 mm
(Volvo et Mercedes étaient généralement les plus épais)
Si vous prenez 0,7 mm comme moyenne.
Acier inoxydable austénitique : 3 mm x 0,5171 kn/mm2. .82736 kn/mm2 pour le laminé à froid.
Acier au carbone : 0,7 mm x 0,3447 kn/mm2
PS 3 mm d'épaisseur, le métal est appelé plaque d'acier, en dessous de 3 mm, il est appelé tôle d'acier,
Cybertruck est un MONSTRE:cool:
[/DEVIS]
vous avez fait une erreur dans les unités !
l'acier inoxydable avec une densité de 8000 kg/m3 et une épaisseur de 3mm fait un poids de 24 kgs / m2
LTN COLUMBO
Pierre
DUSTER PRESTIGE
Erreur de calcul et d'unité !
avec une densité de 8000 kg/m3 une plaque d'acier inoxydable de 3mm d'épaisseur fait 24 kg/m2
