GuyV
- Guy
- Aug 17, 2023
- St. Louis, MO
- Tesla Model S, FS Cybertruck AWD
- Retired
I didn't say I was the one who could do it, I said you fail your own quote by insisting no one, and especially Elon can't. If he felt he needed to do it we know he would approach it from first principles, not be limited by how the experts have always done things in the past.So tell me then how to make traction control not "reactionary"?
There are physical limits, and "theoretical limits". Then there are theoretical limits based on false authority.
Lots of theoretical limits fail when they meet physical limits.
First up you would have to tell me about how a motor inverter controls rpm and torque, then we could discuss "how to fix it", because then we are talking about the same limitations.
Take a look at how "tesla" does it:
It's pretty decent for the conditions, but it has slip before the brakes engage, and that is with two wheels worth of perfect grip, not four with alternating levels of grip. You would think that after decades in the field and in the age of OTA they would know how to "fix it" by now?
So this is exactly what a DM setup will do in the CT that only has the ability to use the hydraulic brakes and traction control to control wheel slip. The only way to improve it is for a DM is to have better brakes that can be dosed so fast and accurately that they can simulate a locker....or simply have a locker.
Now a tri motor CT will be able to control the rear two wheels better, because it has a motor each, meaning it can modulate power for each rear, and a QM even better again with the front, but all will have a "delay" between when the wheel traction changes the torque that can applied to the contact patch of the tyre, and that the motor can respond in kind.
You can see how the wheels all produce varying levels of rotation here, where only one or two wheels are propelling it and then breaking traction. There is never a case it has 4 wheels turning at the same time with traction. Each time one wheel breaks traction it forces more load on the next until that breaks and so on. The cascade creates less effective traction, because one wheel is working against the other, instead of all together.
In comparison a locker act like a "tank track" in that all the tracks move at the same speed and the same torque, even if half of the same track is on ice (no friction) and the other half on solid ground (friction).
So if you want to discuss how, then please first define which motor version you would like to discuss the theoretical limits of, and what constraints or tests you wish to perform to recreate a simple diff lock.
There are a couple of things even I can think to consider. One is that computers are fast enough to calculate projections on the fly rather than be totally reactive. Someone mentioned a thousand times a second, which to the computing power in a new Tesla is incredibly SLOW. Another is that a Cybertruck could read the terrain and evaluate it at that speed. It could be able to see and feel whether it is on mud, sand or whatever, and know what to do about that with AI training to anticipate the optimum application of forces for what will be under each wheel as it moves forward.
