firsttruck
mx
There is no way to 'drive out' from any of these things that are larger than that.
At that point, roads are damaged or clogged up with emergency vehicles, so you should stay put. Not drive a hundred miles while emergency vehicles and supplies are trying to get around.
Most of the events I listed and the geographically area affected had ZERO road damage because most of the area did not experience ANY weather event at all. Only lose of power. City streets with intersections and non-functional traffic control devices would have been a problem but the U.S. interstate highways and many major state highways not dependent on powered traffic control devices would still be operational highways.
Why would most of the outage area be clogged with emergency vehicles if the power outage was caused by malfunction in electrical system 10 miles or likely many more miles away.
Many of these events could have more affect on the majority of ICE vehicle operators who had less than full fuel tanks and now can't find stations that have working pumps or still have fuel.
EV operators that charged every night would have been much less affected and if they have solar panels on their property probably can still add range immediately or shortly when the weather clears (if weather was even a fact at all). Many EV owners who had charged every night would also have energy in their vehicle's large batteries to power critical devices (refrigerator, medical devices) for the EV owners. Very few ICE vehicle owners have stationary fossil fuel generators.
When weather event causes power outage the many of the areas that experiences long duration power outages can be very large yet the same area have little direct damage from the weather event. Long distance transmission lines can be damaged by weather yet many places without power have no significant physical damage, emergency vehicle traffic or local repair crews needed.
** firsttruck - this report has good info and is not very long (can be browsed quickly) **
Published 2004 April 9 by U.S. Congressional Research Service
Electric Utility Infrastructure Vulnerabilities: Transformers, Towers, and Terrorism
https://sgp.fas.org/crs/homesec/R42795.pdf
A spectrum of threats exists to the electric system ranging from weather-related to terrorist attacks, including physical attacks, as well as attacks on computer systems, or cyber attacks. The main risk from weather-related damage or a terrorist attack against the electric power industry is a widespread power outage that lasts for an extended period of time.
** firsttruck - Local streets might be blocked by fallen trees but U.S. Interstates and most major state highways are purposely designed and kept free of trees or likely tree obstruction is minimized as much as possible. **
Highway Safety and Trees: The Delicate Balance
U.S. Federal Highway Administration Office of Safety
https://safety.fhwa.dot.gov/roadway...ecovery/clear_zones/fhwasa0612/fhwasa0612.pdf
High-speed roads and highways, both urban and rural, should have roadsides free of trees and other fixed object hazards. Regardless of the posted speed limit, the risk for vehicle collisions with trees should always be assessed.
Published 2013 August 8 by Union of Concerned Scientists
13 of the Largest Power Outages in History — and What They Tell Us About the 2003 Northeast Blackout
https://blog.ucsusa.org/mike-jacobs...-of-the-largest-power-outages-in-history-199/
3) June 2012
Derecho: Wind storm damaged trees and equipment, cutting power to approximately 4.2 million customers across 11 Midwest and Mid-Atlantic states and the District of Columbia. Widespread tree clearing and line restoration efforts in many cases took 7 to 10 days.
7) August 14, 2003
Northeastern US and Ontario: Transmission system failed for many reasons seen in major outages that came years before. Information was incomplete and misunderstood; inadequate tree trimming caused short circuit; operators lacked coordination. System imbalances and overloads seen early in the day were not corrected due to lack of enforcement of coordination. 50 million people across eight states and Ontario were without power up to four days.
5) September 8, 2011
California-Arizona: Transmission failure was set up by Southern California’s heavy dependence on power imports from Arizona, an ongoing problem. Hot weather after the end of the summer season, as determined by the engineering schedule, conflicted with generation and transmission outages planned for maintenance. Then two weaknesses — operations planning and real-time situational awareness — left operators vulnerable to a technician’s mistake switching major equipment. This outage lasted 12 hours, affecting 2.7 million people.
4) October 2011 Northeast U.S.: Record early snowstorm brought down trees and wires. Outages could only follow removal of snow and fallen trees. More than three million customers in Mid-Atlantic and New England states were without power, many over 10 days.
Hurricane Sandy Power Outages (2012) When Hurricane Sandy hit the East Coast of the US in October 2012, many people lost their property due to flooding and strong winds.
Yet another reason for significant distress was caused by the power outages that affected over 8 million people across 21 states. While in some places the electricity reappeared in a matter of days, other areas had to wait for weeks for the power to be restored.
On the Impacts of Power Outages during Hurricane Sandy—A Resilience-Based Analysis
Published: 22 April 2016
By Devanandham Henry, Jose Emmanuel Ramirez-Marquez
https://incose.onlinelibrary.wiley.com/doi/10.1002/sys.21338
Guidelines for Planting Within Highway Right-of-Way
North Carolina Department of Transportation Division of Highways
https://connect.ncdot.gov/resources/roadside/AestheticEngineeringDocuments/PlantingGuidelines.pdf
Tesla Cybertruck Another Jim Cramer hit piece on the Cybertruck 1682940176729
Trees and Highway Safety - Caltrans
18 mar 2010
Preliminary Investigation Caltrans Division of Research and Innovation
Produced by CTC & Associates LLC Trees and Highway Safety
https://dot.ca.gov/-/media/dot-medi...vestigations/tree-safety-pi-3-18-101-a11y.pdf
Background
To minimize the severity of run-off-road collisions of vehicles with trees, departments of transportation (DOTs) commonly establish clear zones for trees and other fixed objects. Caltrans’ clear zone on freeways is 30 feet minimum (40 feet preferred) from the edge of travel way to a fixed object. Clear zone distances on conventional highways vary depending on conditions such as road geometry and design speeds.
firsttruck
mx
Charge your EV every night because we don't know which idiot is going to try to ruin our day tomorrow and whether they will succeed in their attempt this time.
If your EV is almost fully charged (80% or more) then you might have more time & options than many of ICE owners driving around trying to get fuel they don't have and hours waiting lines at gas stations or not because station is closed.
Get an EV, power wall and solar panels as soon as you can afford each.
The incidents listed below happened without warnings ( NO weather predictions involved).
Probably few emergency vehicles or repair crews clogging most of the highways since the causes were at a few centralized single points of failure locations.
Published 2022 Dec 26
More than 14,000 in Washington state lose power after energy station attacked.
The Christmas Day outages add to an alarming and increasing list of similar incidents in the US. There were six attacks across power stations in Oregon and Washington earlier this month, following a similar attack on two stations in North Carolina at the beginning of December.
By Samira Asma-Sadeque
https://www.theguardian.com/us-news...n-state-energy-station-attacked-christmas-day
Northeast blackout of 2003 was a widespread power outage throughout parts of the Northeastern and Midwestern United States, and most parts of the Canadian province of Ontario on Thursday, August 14, 2003, beginning just after 4:10 p.m. EDT.
Outage Duration: 2 hours to 4 days, depending on location
General Location: Northeastern United States, Southeastern Canada
Type: Blackout
Cause: Software bug in the alarm system in the control room of FirstEnergy
Outcome: 55 million people affected
Deaths: almost 100
https://en.wikipedia.org/wiki/Northeast_blackout_of_2003
Tesla Cybertruck Another Jim Cramer hit piece on the Cybertruck 1682942012719
Northeast blackout of 1965 was a significant disruption in the supply of electricity on Tuesday, November 9, 1965, affecting parts of Ontario in Canada and Connecticut, Delaware, Maryland, Massachusetts, New Hampshire, New Jersey, New York, Pennsylvania, Rhode Island, and Vermont in the United States.
Over 30 million people and 80,000 square miles (207,000 km2) were left without electricity for up to 13 hours.
Cause: failure was the incorrect setup of a protective relay on one of the transmission lines.
https://en.wikipedia.org/wiki/Northeast_blackout_of_1965
Who would’ve guessed that fans of the CyberTruck have leanings towards dystopian futures /s
Reminds me: we don’t talk enough about the 2019 unveil including actors dressed up like characters from The Matrix
Literally no one needed to 'drive out' from the blackout of 1966.
And even interstates are screwed up by power outages. Their warning lights go out, overhead lighting goes out, the traffic control lights at off and on ramps go out. and the accident rate skyrocket. Gridlock spills onto the highways.
Driving when power is out across the county is really, really bad. And in that outage of 1966, the roads were clogged with emergency vehicles!
Whenever the power is out I don't drive anywhere - I use my motorcycle - because I can lane split and shoulder-surf because the cars on the road are going slower than a bicycle.
Has anyone but me in this argument even been somewhere an entire county was basically out of power? Sheesh.
I don't even understand what's supposedly being argued now.
