- JB
- Nov 22, 2019
- Australia
- Cybertruck
- . Professional Hobbyist
It uses a heat pump to condense the water humidity in the air which results in super dry but only slightly warm air to pass over the clothes to dry them. The effect is the air has better capacity to absorb moisture from the clothes, and the clothes are not heated to evaporate moisture, meaning an energy saving from the lack of high temperature heating, and clothes fibers that aren't damaged from the heat, which in turn is what clogs your dryer air filter and is essentially "deconstructing" your clothing. It also connects to and gets rid of the water via your drain, meaning there is no high humidity in closed space cellars or wash rooms, that also promotes mold etc growth and requires adequate or forced ventilation.I have never heard of that kind of dryer.....what is it and how does it work
Obviously, consuming less power also means it can more easily be run on off-grid solar, or allow more capacity for EV charging in a household.
