CyberJay
- J
- Dec 6, 2019
- NJ
- Cybertruck AWD (two), Model Y
- Oncology Biotech Exec | GOD BLESS THE USA
- #31
WOW - thanks and insightful.From doh.wa.gov/sites/default/files/legacy/Documents/Pubs/320-090_elecpuls_fs.pdf
TLDR: Hard to shield things, but unlikely to affect you as non-nuclear military grade weapons (if they even exist yet) would likely be limited to a few square miles. My take: Move away from anything important and the nukes would kill you before EMP was an issue. If you did survive the nukes, everyone without a working vehicle would be trying to kill you to take yours.
WHAT CAN BE DONE TO PROTECT ELECTRONICS
There are two basic ways to protect or harden items against EMP effects. The first method is metallic shielding. Shields are made of a continuous piece of metal such as steel or copper. A metal enclosure generally does not fully shield the interior because of the small holes that are likely to exist. Therefore, this type of shielding often contains additional elements to create the barrier. Commonly, only a fraction of a millimeter of a metal is needed to supply adequate protection. This shield must completely surround the item to be hardened. The second method, tailored hardening, is a more cost-effective way of hardening. In this method, only the most vulnerable elements and circuits are redesigned to be more rugged. The more rugged elements will be able to withstand much higher currents. This method has shown unpredictable failures in testing, though it is thought it may be useful to make existing systems less vulnerable.
EMP AS A WEAPON The non-lethal nature of electromagnetic weapons makes their use far less politically damaging than that of conventional munitions, and therefore broadens the range of military options available. For weapons purposes EMP producing sources other than nuclear detonations have been successfully developed. Several nations, with United States at the forefront, are reported to have developed non-nuclear bombs capable of generating EMPs. Electromagnetic bombs (E-bombs) are specialized, non-nuclear tools designed to destroy information systems. These devices are primarily intended for battlefield application, and their effects would be restricted to a relatively small area. An EMP shock wave can be produced by a device small enough to fit in a briefcase. High Power Electromagnetic Pulse generation techniques and High Power Microwave technology have matured to the point where practical E-bombs are becoming technically feasible, with new applications in both Strategic and Tactical Information Warfare. Although much of this work is classified, it's believed that current efforts are based on using high-temperature superconductors to create intense magnetic fields. The development of conventional E-bomb devices allows their use in non-nuclear confrontations to defeat an enemy without causing loss of life. Regardless of the method of delivery, experts agree that EMPs can be powerful enough to cripple electronic wiring and circuitry over a geographic area as large as several square miles, posing a real threat to the nation's critical infrastructure. In addition, the Defense Department's reliance on satellites and commercial computer equipment to
What about severe Solar interference?
