KuMX
- Ku
- Nov 15, 2019
- Socal
- Cybertruck AWD + 2017 Model X
- Thread starter
- #1
Saw this posted on a Mach-E forum and thought it was a great summary:
https://www.macheforum.com/site/threads/cybertruck-engineering-innovations.32167/
These may not get much attention from the general public, but Cybertruck does have some significant engineering achievements that will hopefully trickle down to other vehicles:
- Fully Steer-by-Wire - The steering wheel is no longer connected to the wheels, first vehicle to market like this (Lexus is also working on this, but has't been released). It is like a force feedback joystick that causes the front wheels to move. The force feedback unit provides return-to-center torque and force feedback based on detected steering load. The lack of mechanical connection also allows a variable steering ratio to be used (based on speed), and the total steering rotation is less than one turn (vs. 3-4 turns for a regular car). This means hand-over-hand steering is no longer necessary since half a turn is full left or right angle. You can turn the steering wheel when the truck is off and the wheels don't move. The required safety redundancy (that allows complete removal of a mechanical connection) is provided by two separate electric motors on the same steering column, with triple redundant sensors. This is the steering rack, I've never seen one with two motors before:
- Fully 48V LV Electrical System - The low voltage system has completely switched from 12V to 48V. There are no 12V components in the vehicle (no 12V ports either, 120V and USB-C only). This is the first vehicle in the world to fully switch to 48V, the traditional automakers have been talking about this since the 1980's but haven't been able to make it happen yet. Hopefully this is a kick in the pants. Higher voltage means the wires can be made smaller, and is also more efficient. All three steering motors draw a combined 5 horsepower at full power, which would completely overload a 12V system (300 amps). With 48V, high output steering devices are possible. I assume there is a small 48V lithium battery powering the 48V system when the truck is off.
- Distributed CAN bus architecture - Everything in the vehicle supposedly runs off gigabit CAN bus network, down to individual lights. This means most wire runs are extremely short and only involve a pair of power and CAN bus wires, eliminating a lot of wiring. This is in contrast to the traditional method where a body control module located in one spot has dozens of wires that run to all parts of the vehicle from it. No more thick harnesses. This is what Jim Farley was talking about when eliminating wiring waste from vehicles. Like other current Tesla models, the Cybertruck also completely eliminates the need for fuses through intelligent power control, which is still unique in the industry.
- 400V/800V switchable pack architecture - The 123 kWh battery pack normally runs in 800V mode for driving, which makes it incompatible with existing Superchargers that only go to 450V. So Tesla invented a switch that splits the pack in two, making two 400V halves in parallel while charging. This works opposite of the Hummer EV which is normally 400V and switches to 800V for charging. It's unknown whether the Cybertruck will allow 800V CCS charging, if so it could break a charging speed record. Here's the switch:
- Exoskeleton - In addition to the battery pack, the exterior body panels are also structural. This means there is no internal structure or crash bars inside the doors, and it still passes side impact tests with flying colors. The steel is extremely strong, durable, and actually bulletproof.
- Quickest pickup truck ever - The Cybertruck has beat the Rivian R1T is is now the quickest pickup truck ever, with a 0-60 of 2.6 sec and 11.0 sec @ 119 mph quarter mile. This performance is available without special battery preconditioning, and apparently unchanged with repeated runs all the down to 33% battery, which is unheard of.
- Bidirectional charging - Tesla calls this Powershare, the on-board plugs can output 9.6 kW (same as F-150 Lightning), and will also support up to 11.5 kW of power output for V2H to power your home. This will require a Powerwall. Similar to F-150 Lightning Intelligent Backup but with higher total output and less integration equipment required (provided you have a Powerwall). It's unknown whether Tesla will allow the Cybertruck to operate in V2G mode with Autobidder software and sell power back to the grid when it's profitable. If this were possible you could make hundreds of dollars per month, since the Cybertruck has the capacity of 9x Powerwalls.
- Largest Windshield and Wiper - At 4 feet long, the blade is the longest ever produced. It is a single blade. The huge windshield is also the largest ever mass produced. The wiper actually changes angle slightly while driving to improve the aerodynamics at different speeds (a form of active aero). When the wiper is on, it parks at the bottom of the windshield instead.
