DrPhyzx
Santa Cruz Mountains
Bolt EV, Ariel Atom
particle physicist
Count me in the camp of saying the other car did not come out of this well. As others have said the front end crumpled to engine block. What nobody else has said is....look at the pavement below the car: oil and maybe battery acid and and maybe transmission fluid or coolant have spilled out indicating significant damage. I think the amount of intrusion of the cybertruck door seems pretty minimal and if crash speed was 50 mph + I would be super impressed.
The damage on the Ford Edge looks is far too mild to be 50+ mph. This is a lot more like what you see at 30-ish mph.
Here is 50kph (31 mph) into a stationary barrier (starting at about :045)
This is somewhat more damage than shown in the pictures. Since an Edge weighs about half of the CT (not quite a solid barrier but 2/3 of way there in center of mass frame), I'd guess this was a 30-35 mph crash, which is definitely a severe crash, but far less than 50+ mph (E \propto v^2 is a killer!).
Tim
DrPhyzx
Bolt EV, Ariel Atom
particle physicist
So looking it up, there's a 2,300 lb weight difference with the edge(4500) and the ct(6800).
Side tests are tested with a ~3K lbs dummy (regardless of class).
Head on crashes are tested @ 35mph to an immovable object.
neat.
You are correct... had it wrong that CT/Edge is 2:1. However, it's easy enough to translate from an immovable barrier to center-of-mass to get an approximate sense of relative damage and I still think this looks like a 30-35 mph crash. NCAP tests are at 50kph as in link to video, which is 31 mph. Sounds negligible but the difference in energy is 27%.
shaneaus
Martin
Austin, TX, United States
Chevy 1500 Z71
My opinion, for what it is worth and because many others seem to be expressing theirs:
I was LE for 26 years and for over seven years of those I was a traffic officer -someone whose primary job is to respond to and investigate collisions. I am actually pretty impressed with the lack of intrusion into the CT.
From a cursory look at the photos and without taking measurements, etc - it looks to me that the CT was turning to it's left at a low rate of speed (due to the scrub from the CT's front left tire) (the front right tire, likely left little to no scrub due to being lifted off the ground by the force off the collision). The other vehicle was, likely, traveling at about 50 mph (damage collapsed the entire crush zone and only stopped at the engine - but, did not push the CT farther than occurred and the striking vehicle didn't travel post impact). This was not a 90 degree angle side impact. This paragraph is based upon looking at the background roadway, the damage, the location and dispersion of vehicle's debris.
The front left of the other vehicle struck the center of the CT's rear passenger door first with the main bumper rail above the lower pan/structure of the CT. Due to the angle of impact the other vehicle, likely, rotated counter clockwise during the impact, and the vehicle stopped at the point of collision. The B pillar didn't collapse and was the apex of the other vehicle's rotation. The intrusion into the front passenger door was less because of those dynamics.
Considering that the majority of the force from the other vehicle was transferred into the rear passenger door at that door's weakest point - I'm quite impressed! And, the B pillar did NOT collapse -despite being struck laterally.
Due to the being no major injuries (unless, they further develop post collision) the LEO's probably didn't conduct a collision reconstruction (take measurements to determine collision forces, vehicle speeds, etc).
I don't think it would be possible to have a better outcome for the CT occupants relative to other vehicles in a similar collision.
Just my humble opinion for what it's worth.
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
what he said
Its4kito
Guest
As a comparison, and without knowledge of speed parameters, I saw this Toyota truck accident on the internet search:
Tesla Cybertruck Cybertruck T-Bone accident at high speed - damage photos IMG_2091
kpanda17
That damage is intense, but it’s impressive how well the structure held up. Honestly curious about the repair cost and whether replacement panels are easy to swap out.
Just having an M3 Tbone, it does not take much in repair cost estimate to total a vehicle these days. Our Tbone, we are all safe and the M3 did amazing, was $22K, therefore the 2023 was totaled.
Lars, Tesla engineering architect, did an amazing job with these passenger boxes that are inside all Teslas. Seeing the damage on our M3 vs this Cybertruck, i'd imagine the other vehicle was traveling in excess of 70 mph. For what speed on impact does Lars design for? At some point, you cannot protect at such extreme speeds, sadly to say.
btw
The Insurance Institute for Highway Safety (IIHS) is considered the most difficult grader in the car safety industry. This independent, nonprofit organization conducts crash tests and evaluates crash avoidance and mitigation technology.
" The Insurance Institute for Highway Safety (IIHS) uses a 37 mph side impact speed for its updated test. The test uses a 4,200-pound striking rig that hits the driver's side of the test vehicle. "
" According to NHTSA standards, the side impact crash test speed for a vehicle is 38.5 mph (62 km/h), simulating an intersection-type collision where a deformable barrier strikes the vehicle's side at that speed. "
in summary, the cybertruck did amazing, now we can only pray the passengers and driver are ok
