TheLastStarfighter
Industrial Engineer
The reg says;"A motor vehicle, other than a motorcycle, shall be equipped with at least two headlamps, with at least one on each side of the front of the vehicle, and, except as to vehicles registered prior to January 1, 1930, they shall be located directly above or in advance of the front axle of the vehicle. The headlamps and every light source in any headlamp unit shall be located at a height of not more than 54 inches nor less than 22 inches."
Exactly. "At least". The CT light bar is 5 lights (we've seen one burnt out), with the two far ends the head lights. The middle is decorative, like the Lightning.
nope what?
you’ve given some strange challenge to somehow prove the headlights ARE on the bumper - which makes no sense
how about you instead find a single video of the CT driving at night on roads WITHOUT the lights on the bumper
you won’t
and if you did, it’s because it’s broken
I really don’t understand your insistence, apparently founded entirely and only upon having seen that the 2019 prototype had headlights in that area
man, if you’re this insistent, you’re seemingly going to be distraught when the news hits you
PilotPete
Pete
Porsche, BMW, M3LR on order
Chief Pilot
Agreed. That could be the arrangement. Or it could just be DRL. I see where the ends appear brighter. Don't know if that is the headlight or not. I would LIKE for it to be, but...
In the end, I like the truck. Ready to write a check...
Michigan
Dual Motor Reservation Holder
This was obvious since the beginning (and I’ve said so on many occasion). Diffused light is.. well, diffused light. By its very definition, it projects in a diffused manner and therefore cannot be used a main beam. Hence, the light bar was *never* going to be the main beam *unless* they had a clearing for some projector lights within the bar itself. Alas, that would have ruined the aesthetic.
Not to change subjects, but how badass would it be to have PLD glass in front of the headlights to both keep the aesthetic (frosted and uniform) when the headlights were off, and then when the headlights turn on the glass changes to clear to allow a focused beam of headlights. :cool:
Stuck4ger
Cape Canaveral, FL
Aerospace
Have we really seen a burnt out portion of the light bar or have you seen a still shot from a video of a sequencing light bar?
even if we had, it would make no difference
tomorrow you could see a Lightning with portion of its DRL burnt out, and it still wouldn’t mean the Lightnins’s headlights are there
TheLastStarfighter
Industrial Engineer
I would never lie to you.
We've seen the same truck multiple times with a burnt out accent light on the light bar. It's been all over the forum as it was one of the most common test trucks running around. Here's a crappy picture of it:
Tesla Cybertruck DRL, headlights, fog lights, sidemarkers, tail light bar ON in night time video (on Tundra Cybertruck leaving supercharger) p3maime0lzhb1
TheLastStarfighter
Industrial Engineer
why would Tesla move the headlights lower than on the prototype?
why would Tesla delete the 6th seat
why would they add four wheel steering
why would they add larger plastic bumpers
regardless of the reason for the outcome, it doesn’t change the outcome
TheLastStarfighter
Industrial Engineer
Space - probably still an option
handling, obviously
Crash/pedestrian standards
Move perfectly working headlights to an inferior position? No reason. That's why they didn't. Tesla is an engineering/logic driven company.
jesus man, I’m telling you I know and can confirm independently - free from conjecture or assumption - which the headlights are
seems your glitch is your incorrect assumption that it is an inferior location
because the engineering/logic driven company you describe, has placed them just above the bumper - which tells me it’s not an inferior location
Have a good one
TheLastStarfighter
Industrial Engineer
Have a good one
What is your source?
