- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
I think the air resistance of the trailer is going to be higher than that. They are typically not very aerodynamic. Just slightly better than a brick, so call it 0.9 (the cyber truck is approaching 0.3, so almost 3x the drag coefficient). If its a 5th wheel, it sits up high, and probably max width, so the combined frontal area will be like 60-80 square feet (2x the CT's 30-ish). Drag is a combination of the coefficient of drag x the area, so that puts the aerodynamic drag of the combo around 5x the CT. Air drag is the bulk of the resistance at highway speeds, so the range will be proportionately lower. I would not be surprised to see it down around 100 miles.
I said that any range estimates I would give would be exceeding crude and I'll continue to hide behind that statement. If we assume that rolling resistance is 20% of consumption (as I did before) and that the CT's consumption un burdened is 485 that implies drag consumption of the CT is 388 Wh/mi. Putting the trailer's drag at 5 times that gives it consumption of 1940 for drag. Our assumption assigned 97 Wh/mi to rolling resistance and we might assume the trailer's rolling resistance consumes twice that as it weighs twice as much (we're still talking the huge 5th wheel rig here) or about 200 Wh/mi. That gives 1940 + 200 = 2140 for the trailer to which must be added the 485 for the CT itself meaning a total consumption o f 2625 Wh/mi. This is 5.4 times the demand for the truck alone and range will thus be less that 1/5th (18.5%) of the CT by itself. For the 500 mi rang model that's 92 miles. But this is also a very crude estimate. Someone who has one of these and want's to get an idea should go out and measure the increase in fuel consumption per mile with his current ICE truck. The measurement won't exactly match what's going to happen with the CT but factors of 5 would certainly be detected.
Note that there are "aerodynamic" trailers made such as the one that I mentioned in #12.
Also note that the towing vehicle shields the trailer to some extent.
Do keep in mind that there are other consumers of energy (transmission loss, bearing loss, slip loss) so that wh/mi vs speed does not go as the square of speed as these other forces tend to swamp drag.Air drag is proportional to speed squared, so the air drag at 75mph is going to be almost double what it is at 55mph. Keep the speed low to get better range.
