First Dry Cathode Battery Process Cybertruck Spotted at GFTX!
The cathode material is usually applied in a wet mixture. It has to be baked at high temperatures and worked with chemicals to ensure it adheres to the support structure. A dry cathode is more or less just printed onto the support structure in a manner like toner from a laser printer. It doesn't require the long baking cycle or chemical treatment. It makes it much less expensive for Tesla to produce. As a side benefit, there is some thinking that the process will result in a thinner, more consistent layer enabling more power per kilogram of weight which could mean higher capacity batteries/longer range.
And alot alot less water, which is a sticking point at their current factory sites.
greggertruck
greggertruck
g
Zimbabwe
www.twitter.com
Dual-CT
Ed1
NYC
2011 Highlander hybrid
Real estate
Sorry but how do we even know it’s a dry cathode cyber truck? Looks just like a regular cyber truck with a wrap. ?
Clarification:
The cathode wet process uses a solvent which is reclaimed and recycled.
The new cathode electrode material generation process uses less water (zero net) due to skipping the nickel sulfate step, but that is independent from applying it to the metal foil.
Tesla Cybertruck First Dry Cathode Battery Process Cybertruck Spotted at GFTX! SmartSelect_20240727_180849_Firefox
Tesla Cybertruck First Dry Cathode Battery Process Cybertruck Spotted at GFTX! SmartSelect_20240727_180620_Firefox
Tesla Cybertruck First Dry Cathode Battery Process Cybertruck Spotted at GFTX! SmartSelect_20240727_180647_Firefox
Ed1
NYC
Real estate
Well that explains that! good to know for those that are not so involved with the topic. Thanks. ?
