cyberHoward
- Nov 29, 2019
- Northern Ohio
- Cybertruck AWD Foundation
- Thread starter
- #1
PDF Download: Service Bulletin PDF: Inspect Door Assemblies For Low-Pitched Noises And LH Side Mirror Shaking
I have complained since the day I picked up my truck about the low rumble and my mirror vibrating on the driver's side when driving at high-speeds or hit with a strong cross-wind. My Tesla Service Center has really tried to fix it including two new doors. I think after the third door on my driver's side it was slightly less shaky/boomy. Early on they even listed no engineering solution to the mirror issue. You could hear and feel it on your knee shaking the door. The noise is more like a bass drum as the wind hits the door (very low frequency). I had even tried taping my door gaps closed and getting in on the passenger side to see if the draft was catching the door funny. I actually had resign myself to living with it as a design flaw. I have ridden in 3 different Cybertrucks and they all had the Low-pitched booming and vibration at higher speeds.
I saw a post earlier this fall from someone regarding SB-25-10-002, but I can't track down the post. When I read the service bulletin, I was shocked when I read the following inspection notes. "Test drive the vehicle on the highway, at speeds greater than 60 mph (96 km/h), listening for a low-pitched booming or vibration coming from the doors, and also checking the LH side mirror glass for visible shaking/rattling." This is exactly what I wrote on my first list of items when I picked up my Cybertruck from the dealership.
I really wanted to believe Tesla finally acknowledge the issue and had an engineering solution, but it was hard to believe after having doors replaced this butyl patch and adhesive was going to solve the issue. I apprehensively contacted the service center and listed this SB-25-10-002 along with cantrail recall replacement, seat motor (second one replaced), and some cosmetically things I paid to have fixed. The initial response was a diagnostic fee on the door noise and through some deep conversations with the service manager, he agreed to have his master mechanical review the need for that that SB without charging me. Honestly, the Service Manager was very nice about it despite seeing two door replacements.
I picked up my truck last night. Well, my early report after driving home at 70-80 mph with cross-breezes at 20 mph I actually think it is fixed or at least the driver's side is fixed. They did not do the passengers side which will be a follow on post, since I took it and told them I will try it out with the driver's side done, but would likely comeback for the passenger side if it worked. There was no vibration in the mirror, no thunder booming, no vibration on my knee from the door booming in and/out. The truck seemed much quieter. I had a 35 minute drive with no indication of the problem. There are some 30-40 mile cross-winds happening today, hopefully I will get a chance to go out on the highway and test it some more.
I think most owners don't realize that the CT should not be booming and vibrating and would be surprised with the difference.
