High voltage battery replacement needed
njwilson
Nick
Houston
cybertruck model 3 performance
I was on my way to the gym about a week ago and my cybertruck shut down. Tesla towed it to their facility and told me that the high voltage battery needs to be replaced so they ordered one. Tesla is now telling me after a couple date changes that the battery won’t arrive until sometime in July! Also, they said that the battery pack will be refurbished and the cells will be new. Anyone else experiencing this?
Bound to happen here and there, but you may be in great luck with this actually. Could end up with the newest generation cells.
What year truck and how many miles?
I would push for a new pack assuming you bought the truck new the pack should be as good as the pack you bought, not to mention the loss of vehicle for a month.
njwilson
Nick
Houston
2025 with 7500 miles
Planet Earth
From what I have heard all Tesla replacement battery packs are refurbished.
JCERRN
J
Around
Yeah
I would escalate for new battery replacement given such low mileage. Refurbished is not equivalent to new.
UberNoob
CyberBeast & M3P
Desktop Security Engineer
I once read somewhere they replace battery’s on warranty, with slightly used once’s to match your current state. Example if you have 100k miles on it they will replace it with one that is equally used. Unsure how they measure it miles or battery cycles , maybe health.
But I’m with the crowd to replace it with a new pack. If the day comes when I have to buy a battery, it dang well better be new.
OP said the cells are new, but pack is refurbished .
Sounds like new case and cells with less than new ancillary components. Pyro fuses, PCS, DCA, busbars, harnesses ...
You are owed an equivalent replacement under warranty, not a completely new part though.
kpanda17
When the legacy motor fails under warranty you get a crate motor replacement, rebuilt
Used
The rebuilt pack with new cells is even better
The guts, cells are new
They are giving you a good option
Most likely the new cells
Jager
Jeff
Virginia
If the replacement pack is truly refurbished - as I would expect in this scenario - I would be very surprised if the cells themselves are actually new.
Local service people often have incorrect information.
Friday
Grover's Mill, NJ
HV batt replacement has be refurb units since early model 3's. Coworker had a model 3 hv batt need replacement at 12k miles, ok, but the battery warranty does not zero out with pack replacement. His hv bat warranty was not extended. Not surprised to see same coverage on Cybertruck.
meinnovations
Seattle
MS, MY, MX, CB
engineer
I concur. I have not seen data nor heard stories about CT refurbs but have heard many bad for MX/MS.
