Insurance and bodyshop nightmare?
Roy2001
F150 Lightning
To my instinct or extremely limited knowledge of bodyshop and stainless steel, it is extremely hard to repair the stainless steel sheet/shell.
Now think about a dent, you can easily fix it using paste, buffering and painting. But how can you fix it with bare stainless stell?
Further more, the only way to fix from any kind of accident (local road crash or parking lot scratches) is part swapping.
Any thoughts?
Regenshire
Josh
Spokane, WA
Model 3 RWD LR, Model Y Perf, CyberTruck AWD Order
My assumption (knowing next to nothing about body repair) is that body shops will order replacement panels from Tesla and afix them. That is likely the cheapest method to fix damage to the skin. It doesn't need paint, so that likely is fairly low on labor costs I would assume.
Roy2001
Roy2001
F150 Lightning
I doubt since a lot of minor scratches costs a few hundred dollars would need thousands of dollars to replace parts.
charliemagpie
Charlie
CybrBEAST
If it's a minor scratch on paint, from a few bucks to a few hundred.
If it's a minor scratch on SS, steelo pad, and buffer it out.
If it's a more significant dent, the SS panel I expect would cost more, and the labour to replace it would be the same, but there is no paint. CT repair would be cheaper.
Overall, maybe there is no significant difference. We would have to see the cost of SS panels.
Roy2001
Roy2001
F150 Lightning
How about a ding or small dent?
SSonnentag
Shawn
2018 MX and 2023 MYP
Oxyacetylene torch and a ball peen hammer? ;)
Any thoughts?
Don’t. Problem solved.
rbalkun
Rob
East Haven, CT
They hit the truck with a sledgehammer and it didn’t leave a scratch….maybe you should get a different vehicle if you think you’ll do a more forceful impact .
charliemagpie
Charlie
CybrBEAST
Small dents can be removed by a technique that doesn't require painting, that would be cheaper.
But in that hypothetical, in a similar impact, the CT would not have a dent at all.
If the CT was dented in an impact, what would happen if it was a normal car ?
IMO, the CT is at least no more expensive. Probably cheaper on average.
pat11215
pat
NYS
Tesla Model 3
Any thoughts?
no worries there are alternatives ...
Tesla Cybertruck Insurance and bodyshop nightmare? istockphoto-140088435-612x612
mhaze
mhike
Guys that fabricate commercial kitchen stainless steel equipment can cut out a piece from the CT panel,, tig weld back in a piece, and use abrasive pads to sand down the weld until you can't see it at all. Then the entire Cybertruck panel would have to be refinished, essentially sanded down for a uniform appearance.
This is routine with classic and custom mod cars, although it is with mild steel and not stainless.
Whether these processes are cheaper or more practical than ordering new panels are separate questions.
