Rutrow
- Dan
- May 25, 2021
- Little Rock, Arkansas
- Model S, Model 3, CyberTruck Tri-motor reservation
- Firefighter
- #1
At the CyberTruck reveal Tesla listed the tow capabilities for the Dual-Motor CT at 10,000 lbs. and the Tri-Motor CT at 14,000 lbs. but I can't get my brain to accept that there should be such a wide difference between the two.
To understand tow ratings it's important to know the components of testing used to determine their limits. The intuitive thought is that tow rating is how much weight can the vehicle get up to highway speed, but that is least important, and often the easiest test for vehicles to pass. More important metrics and more difficult to achieve relate to safely stopping and maneuvering the maximum load. Let's first touch on the components of SAE's J2807 standard.
SAE J2807 is a voluntary standard agreed to by vehicle manufacturers to allow buyers to objectively compare different models. The testing, pertinent to CyberTruck* includes:
If I may, for purposes of this discussion, (given that three Model 3 motors [Tesla Semi] can propel >82,000 lbs.) we'll assume that even the Dual-Motor CyberTruck will have no problem achieving ALL of the minimum acceleration components at weights far greater than the Tri-Motor CyberTruck's maximum tow rating, and I also doubt that the Davis Dam Grade will result in any overheating for CyberTruck. In my opinion, the limiting components will be the stopping and maneuvering tests. These tests rely on the vehicle tire's ability to maintain enough friction with the road surface. And that is the nut of my feeling that both DM and TM CT will have nearly the same ability.
Friction at the tire patch, if both versions use the same sized tires, is entirely dependant on the downforce on the tires. Greater vehicle weight will increase the downforce, but will also contribute a higher inertial force resisting the tire friction. I am totally ignorant about whether increased weight would result in increased stopping/maneuvering ability or decreased stopping/maneuvering ability, but my gut tells me it's the latter (I'm open to discussion about this). Reviewing ICE truck CVWRs, every optional component (4WD, larger fuel tank, heavier axle/differentials, etc.) on a truck seems to reduce the payload and trailer capability by about the weight of that optional item. Is that because braking friction doesn't appreciably increase? or is it that the weight hurts them in Davis Dam test?
Regarding the two versions of CyberTruck, a large difference in tow rating could be explained by the two versions having markedly different grade of suspension/frame components. But this would be very un-Tesla-like. Tesla tends to make as many components identical across all trims, even across many models (S & X, 3 & Y). I think that suspension, cooling, steering parts will be the same for all CyberTrucks. Unless the Dual-Motor has vastly underpowered motors, I can't see why the tow rating would have any difference at all. If anything, the larger battery on the 500 mile range version should REDUCE the payload/trailer rating!
Unless...
Tesla decided to placard the two trims differently to create a market for the more expensive (higher margin) version. My thinking is that if think you need the Tri-Motor, not because of range, but because of its tow rating, you might want to put a Dual-Motor, 10,000 lb. tow rated truck to the J2807 test at the trailer weight you need. For instance, you're a plumbing contractor who tows a backhoe to jobs around your area (<100 miles/day). If it CAN safely stop, maneuver, and hold, even a 14,000 lb trailer, why would you spend the extra $20-30,000 for the top trim? I'd love to see somebody like Munro, or TFLTrucks put a Dual-Motor CyberTruck to the test.
For me, it will be the range I'm after. I want to tow a 9,000 lb Airstream around the country so getting from SuperCharger to SuperCharger in the rural west is my determining feature. But if the 500 mile version doesn't come out soon (by the time my RN11275... reservation comes up) I just might give the Dual-Motor a try. I recently put down another reservation (RN119 ) just for this reason. If a 350 mile truck won't work for me, at least I'm in line for a longer range version in the future.
I'd love to hear folk's thoughts on this, but instead of simply telling me "You're WRONG!" I'd like to hear the logic behind your opinion.
Thanks!
*non-dually, tow rated for >3000 lbs.
**maintain understeer along a 300' circle
***State road 68 and 163 from Bullhead City AZ into Nevada
- 0-30 mph within 12 seconds
- 0-60 mph within 30 seconds
- Passing acceleration from 40-60 mph within 18 seconds
- Five 16' launches up a 12% grade within 5 minutes. In both forward and reverse
- The parking brake alone must hold on that 12% grade, forward and backwards
- 0-20 mph stopping distance less than 80' without leaving a 11.5' traffic lane
- Safely** steer around an arc at 0.4g of lateral force
- Davis Dam Grade*** test without overheating
- 12 mile uphill grade, averaging 5% slope
- Done on a day over 100Ė F
- A/C set to maximum cooling
- Maintain a speed >40 mph
- No warning lights, no diagnostic codes, without loosing any coolant
Unless...
Thanks!
