Loud THUMP when raising
Macgyverfever
Regular Don-Won
Tn
MYP BLUE/WHITE, M3RWD GRAY/BLACK
Multifaceted IT Professional
Anyone experience a loud 'thhhUMPPP' noise when raising the truck to high or extract? I'm in AWD fyi
That doesn't sound right, but is there any motion to the body of the truck when the sound happens or ground discontinuities under the truck?
Thump shouldn't happen as far as I know, but it is shifting weight around which can cause rocks or pavement or load to shift around.
Macgyverfever
Macgyverfever
Regular Don-Won
Tn
There was motion and was the first time I did extract or high, but if course I can't replicate it. I now record everything so maybe I'll get lucky.
jf64k
OP, was your foot on the brake? I remember reading on here someone had noises when lowering/raising while depressing the brake.
I also remember someone (@Cybergirl ?) saying they heard a loud “pop” when going to extract.
agordon117
Ohio
cybertruck foundation awd
The wheels get closer together as the suspension goes up. This can cause some popping noises from the tires sliding if they aren't free to move during the transition (while foot is on the brakes, parking brake is on, or even just on asphalt/concrete)
Freemarket
Southwest
Stay at home Daddy
I definitely experience the same on my epoxied garage floors. No cause for concern. Hopefully same for you OP.
Macgyverfever
Macgyverfever
Regular Don-Won
Tn
Probably was and didn't even notice it smh thanks R body!
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
I have experienced this on high traction surfaces. Try it on dirt and see if the pop happens again.
PeterOT
Peter
San Jose, CA
2019 Model S, 2023 Model Y, Cybertruck
I also have the loud popping (a single clank or pop) the two times I've raised to extract just to show friends. Both times it was in my driveway on concrete.
TruckGenio
Boston
The tires rotate as it’s raising so I wonder if it has to do with it trying to rotate and being on concrete.
KevD0g
Mars
electric
You may have had your foot on the brake when it was being raised. The sound was likely the disc brake pad breaking away from the rotor as the wheels slightly rotated while raising....
Macgyverfever
Macgyverfever
Regular Don-Won
Tn
You may have had your foot on the brake when it was being raised. The sound was likely the disc brake pad braking away from the rotor as the wheels slightly rotated while raising....
Didn't I tell you guys to tell me not to do that?
