Low charge rate?
Coaly
NE-PA
Ford Ranger, Escape, Model T
Appt made for next week. At least I can charge, albeit slower.
I would dial amp charge rate down to prevent the half of inverter still working from maxing out at 24. IF heat from high amperage is breaking a component down, that may extend its life to get you through the time element.
It would be interesting to find if the failures have been charging with wall connectors at 48 amps Vs. failures using the mobile connector allowing 32 amps.
Have to start somewhere to rule things out.
Sturdybirdy
Jesse
NorCal
18 Ford f150, 24 Model Y, Cybertruck
Self Employed
It’s an epidemic. Same thing just happened to my truck. 😢 Does it get worse with time? I can’t get to the SC until the 6th of April. First time I’ve had a ā€œrealā€ problem with my truck.
mcvaughan
Matt
Houston, TX
Does anyone know if these failures are reported in the Tessie app? I looked a bit but didn’t find much.
If you tap the bell icon on the upper-right corner, you can view the "Firmware Alerts" (which includes any Service Alerts). Each alert includes a full description, and a "incident rate" based on Tessie user data.
Tesla Cybertruck Low charge rate? Screenshot 2026-03-06 at 1.15.10 PM
jf64k
Depends. Mine went to 24/24 and would supercharge. It worked fine for over a week, but did start to give me some ā€˜charging stopped’ alerts. Mine is at the SC today getting replaced.
Some have been at 24/24 for months apparently (they didn’t realize there was a problem with the PCS).
Reactions: REM
Sturdybirdy
Jesse
NorCal
Self Employed
Thanks. That’s good to know. I haven’t tried supercharging yet. Seems very odd that this is happening to so many in the same short period of time. My truck has around 25k miles and I bought it in July ā€˜24. It’s one thing if everyone with similar miles and purchase dates had this popping up, but there doesn’t seem to be any rhyme or reason—not that I’ve looked into it very closely.
Reactions: REM
jf64k
Mine was FS AWD, May 24 delivery, 33k miles.
My SC got it done in one day.
Tesla Cybertruck Low charge rate? IMG_0493
Chesapeake Beach, MD
'23 MYLR, FS Cyberbeast 280xx
Serious question for the group:
Has anyone had the PCS replaced and then go bad again? Or, is the updated part more robust?
I've got about 34,000 miles on Fluffy and wondering if I should be concerned.
mcvaughan
Matt
Houston, TX
yeah I’ve been there. Nothing showing up.
Eka
Ekaterine
The land between two rivers.
Model Y, Cybertruck
disabled
I saw a report of that in another thread. I think the first time got a -E version and second time a -G.
Reactions: REM
RoboTaxi
Kansas
Beast when the gods bless me
I gotta get a faster charger to potentially cause the issue while in warranty. I’m probably the only CT owner charging via 110 outlet 😬
mcvaughan
Matt
Houston, TX
Truck went in early this morning. Ready to go at lunchtime. Awesome work by Tesla service. šŸ‘šŸ»
