Stuck4ger
- Dec 6, 2019
- Cape Canaveral, FL
- Cyberbeast
- Aerospace
And the benefit for tires is what exactly? Reduces the chances of:Nitrogen is a real benefit for tires, it's not a gimmick, the only real question remaining; "Is it worth the time and money to go out of your way to use it?".
I don't use it, so that tells you that it's not worth it for me.
1. Corrosion of the inner wheel surface
2. Oxidation of the tire rubber
3. Excessive PSI swing due to tire heating up at highway speeds?
4. An overheated brake causing a fire and an explosion that destroyed the vehicle?
5. What else?
I’ve never been told any of the above happened on any of the vehicles that I drive, so I don’t consider it something to worry about. I do consider dry nitrogen important in the tires of the high speed aircraft that I’ve flown.
