Jabman
New Jersey
Tesla Model S, Ram 1500
I made my first appointment for the PCS failure on March 27th, scheduled for April 23rd. Part wasn't delivered so rescheduled to May 28th. Part still not delivered so rescheduled to June 22nd. Communications today revealed that the part still isn't delivered and it doesn't seem like anyone knows when it will be or where I am in the parts queue, or even if there is a parts queue. Has anyone been waiting for more than 3 months for this repair?
What frustrates me is that I'm reading about some people waiting only a few weeks and getting a repair. Also new vehicles being pushed out, but I'm waiting for three months for a part in a vehicle actively in production with no communication other than my monthly reschedule?
I’m going on 2 months. I’m hoping the revised part is the permanent fix and this is the last time I have to deal with this
btcrealm
Brian
Virginia-ish, USA
btcrealm.com
NOC
I know someone got bumped up in queue (assuming there is one) and got it back in a little over 3 weeks. Their truck was dead on the side of the road. It had screens and AC/heat but it wouldn't even go into gear.
He also had to get a rental from Tesla so I think that probably had something to do with it.
SCTesla
22 Model S, 24 CT
Mine was just pushed from this week to August. They asked if my truck could run and I said yes and then said they would need to push it out for more serious PCS replacements.
'23 MYLR, FS Cyberbeast 280xx
Check for alerts under service mode. Partial failures may not show up on normal UI.
Also try charging at 48A.
WILCO. I charge at 30 amps but I'll check for partials in the morning.
Edphonse
Washington
2021 Ford F-350 4x4 CC SRW 6.7L Powerstroke Diesel, 2024 Cyberbeast
The PCS failure mode hasn't produced safety issues. I'm not sure what you mean.
Tesla has been proactive. What else do you want them to do?
I know this is a few months late, but my first pcs failure (sept 2024) threw a critical alert issue, disabled rear steering, put it in limp mode (4mph), significantly reduced the power assistance to front steering, and threw alerts about potential loss of all power and braking. Only way I see it being a bigger safety issue would be if it burst into flames. Software updates may have helped minimize that type of failure, but no one can convince me a PCS failure is not safety related. I just lucked out I was on a 25 mph side street during the day when that happened and not traveling down a freeway at night.
That was a DCDC failure in the PCS. Charging is a DCAC failure. Two different functions in the same unit.
Dazureus
US
'21 Model Y, '24 Cyberbeast
Just got a call from my local service center stating that the PCS has arrived and I can keep my appointment for Monday 22nd. I'm not sure if it naturally arrived after a three month wait, or if the found a part because I texted them a wall of gentle displeasure. I'll confirm the revision part number and cross my fingers that what I'm given will resolve the issue forever.
Eka
Ekaterine
The land between two rivers.
Model Y, Cybertruck
disabled
Olny diamonds are forever, and every kiss begins with K.
They used to make some high power semiconductors with a diamond substrate. Diamond was also used for radiation hardened chips. It is a far more robust substrate than silicon.
Sjohnson20
Cybertruck AWD, Model Y
I took my truck in to Tesla service today for a left camera problem and some other errors in service mode.
The advisor mentioned a bulletin about the PCS issue. But said that since my truck charges and doesn't have the error they aren't replacing. She also said it was up to 2 months to get one. I didn't even mention PCS so they are very aware.
Reactions: Eka
roadrunner32
Charles
houston
'21 model Y, 2025 cybertruck
retired electrical engineer
I'd lost my key card and was in processs validating a new card, un announced to me, my truck stopped charging before reaching 80%. I'd thought it was done charging but noticed it was at 52%. Scrolling down the notifications list and there it wa`s: PCS2_A051. Oh crap, thought I was safe because my CT is late model 2025 with 79000 vin and was told I have a Rev G on the PCS module.
So this brings some questions:
1. Is this an intermittent problem because it is now charging up to hopefully 80%?
2. It just so happens that I've finally got a wall charger and installed it two weeks ago, I'd been charging on a 4 yr old non Tesla mobile charger. Is it a coincidence? Are all of you that have PCS failures been using Tesla's wall charger?
3. Is it absolutely only the AC charging that is affected. I have a road trip coming up in two weeks and absolutely don't want to be stranded on I-45 between houston and Dallas.
4. It is VERY dissapointing that my truck did not notify of this problem. Am I missing something in my alerts on the phone, I do get messages that the tail gate etc is open. And being aware that many are having this issue I've been checking the alerts every week or so.
roadrunner32
Charles
houston
I had something similar if not the same, "disabled rear steering". SC had it for a week and said it was a connector that came loose. it was an easy fix they said, just had to plug the connector back in.
