AussieCyber
Canberra
Nissan
They need to target the larger rear glass roof section from heat and add along the two inside edges two sets of small plastic rails (like the sliding vault cover but inside UNDER the glass roof).
The can be drawn from the top (internal) point apex of the glass roof & be able to recede back along the rails down in down behind the rear seats on the inside of the vehicle.
The material can be a light material with heat reduction capabilities and able to be bent/retracted.
Elon, you listening ???
2019 Tacoma TRD Pro
Think about how durable and long lasting the stainless steel bed is going to be. And no wheel well bulges!
Blue Steel
MP
Portland OR
Tesla Model X, Polestar 2
Product Specialist
It breaks my heart to think of people spraying their stainless steel, LED lit beds. But then again, my bed will be mostly used for groceries, so I probably shouldn't talk.
I am on the Team Bone-Stock. But I expect to see:
1- Wheels
2- Wraps
3- Some sort of brush guard on the front
piperwarrior99
Paul
Toronto, Canada
Ford F450
Self employed
I will be adding a electric tint to side windows and sun roof. Those who dont know, electric tint is where with flick of a switch, tint turns to opaque or transparent. I like to have glass transparent in winter so sun can keep the car warm and summer the glass stays opaque so sun don't heat it up. I installed it in my current F450 in 2017 and it works like a charm. Only downside is it uses battery so if I don't drive my truck for 2 weeks like when on vacation, I have to jump start the truck. This will be solved with CT as it will stay plugged in.
Ge’Rron
Gerron
Brooklyn,NY
Accountant
1 . Automatic step bar which lights the road when you are getting in or getting out . 2 . Roof box . 3 . Drainable front trunk that can be a cool box .
Reactions: CTM
Deleted member 3316
Guest
  1. Winch (to pull through all those that can’t follow)
  2. UHF radio (to call back to those who can’t keep up)
  3. Portal axle Hubs (because too much clearance is never enough)
Winch should be mid mounted to pull from front or rear.
UHF could be integrated into UI but modern handpiece controls would provide welcome redundancy.
Portal axle hubs reduce torque forces on drive shafts and increase torque at the wheel whilst also providing epic running clearance.
Bigsur345
MJ
DFW, Texas
2017 Honda, '72 Ford Ranchero, 2017 Moar Rapt II E-Bike
Civil Engineer
Here are my predictions;
1) Aftermarket wheels and tires
2) Vehicle wrap
3) Paint factory wheels arches/flares
My 3 items
1. Four wheel steering
2. Port(s) to plug in separate solar panels
3. Ability to swing the tailgate horizontally like the Honda Ridgeline
drcarric2650
Don
Tulsa, OK
98 F150
No, I think it should be on the outside, and be solar panel.
Deleted member 3316
Guest
Yep they have this in the Citroën C4 hatchbacks with full panoramic roof. It works really well at keeping out the heat. It’s basically a roller blind in channels. Model S, 3 & Y could all benefit from something similar.
Whiteaker
Gary
Model S, Cybertruck
Airplane Mechanic
My wish
1. solar panel armored glass( get free miles EVERYDAY)
2. Fridge in the Frunk and or trunk under bed.
3 Lighted collapsing step up rails!
D101010
David
Minnesota
21 MYP
Mirror delete. ;)
Semi trucks have already started the process to remove side mirrors and go with cameras I hope that will go into effect by the time we get the truck. In Minnesota they do not require side mirrors for non commercial vehicles. Maybe they will have a mirrorless option:)
