Speedr
Dual Motor Cybertruck
Just wanted to show how simple it is to remove and re-install the cover over the trailer hitch.
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! 1
There are 3 fasteners holding the cover on (see below):
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! 2
They are all pointed front to back. Just turn them a quarter turn with a large flat head screw driver (very low effort).
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! 3
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! 4
Do this for all 3. Once done, it literally falls into your hand.
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! 5
Complete view of it removed.
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! 6
To re-install, just hold it in place and turn the fasteners the quarter turn the other way. Those tabs are for placement, and don't snap in or anything, so it's really easy and low effort to put it back in. This is done vertically BTW, NOT front to back. You're just lifting it up back to where it was, and then turning the 3 fasteners.
FYI, I'm just posting this since some might be gun-shy due to the way some Tesla add/removals can break things if not done exactly right (I'm looking at you Model Y Trailer hitch cover). This is NOT one of them, and is probably the easiest add/removal I've ever done, regardless of vehicle...
Limes2
Chicagoland
2025 Cybertruck AWD
Yes, took mine off earlier this year just ot make sure everything was there. Haven't towed anything yet.
koolio
Greater Boston, MA
Just did this a few weeks ago. Great instructions and it’s super easy.
Just an fyi for anyone else’s removing it: on mine, after turning all three “screws”, I had to wiggle it a little to get it to come off.
jeniferkey
Jennifer
Fort Worth, TX
Cybertruck and Model 3
I do it frequently, but still forget which way to turn reaching up and doing it blind. I’ve debated replacing with thumb screws, but I don’t want it too obvious for someone to take. Still worth it to not worry about running into the ball like I would with my old truck.
Cyber Pete
Peter
Duluth, MN
2024 FS Cyberbeast
I've suggested to Tesla to redesign the head of the three removable slotted head fasteners to a low profile wing type head similar to what's on the opposite end of the current fastener which would allow for a no tool required (screwdriver) for removal.
Tesla Cybertruck PSA - Removal and Re-install of Trailer Hitch Cover - Super simple, don't be afraid! IMG_3275
Doberbane
Robert
Idaho
2021 Model Y LR, 2024 Cybertruck AWD
Are US quarter will work too. Not sure about a Canadian quarter.
Quarters are what I usually use. I’ve always got some quarters for buying lemonade from kids in the summer. Or in case I come across a pinball game 😁
Jimo
Jim
Shreveport, LA
2023 TESLA Model X, 2003 Thunderbird, 2024 Cybertruck Foundation Series
Side note: you must be lying on the ground to do this! So place a mat!
linh3203
Richard
San Bernardino
CT25 awd
Thank you. Are we able to just leave the tow hitch on there and not put the cover back on? Would it cause any type of damage?
I've noticed recently that, while Canadian quarters still work, they are about 37% less effective. 🤷‍♂️
Seriously though, the hitch receiver cover is easy to remove normally, but it becomes exponentially more difficult if you are stuck in the mud or snow up to bumper lever and need to access the receiver to use as a recovery point.
Pro tip:
If you think you (or a buddy in another vehicle) might become stuck and need a rear recovery point, remove the receiver cover before that happens!
While the cover might prevent some amount of mud or sand from fouling the receiver slot, it's no big deal to leave it off, just make sure it's free of sand and mud before inserting a ball mount into the receiver. The cover is also part of the rear aerodynamics treatment, but probably pretty minimal impact on that.
JFD361
Art
Pennsylvania
2024 cyber truck
Is on, easy off. Towed a big mower over the summer. Towing is easy. Going to try the ride hight option to bring the hitch up to the level of the trailer hitch.
True, "righty-tighty, lefty-loosey" only works if you are looking down at the head. If it's hard for you to reverse that in your mind's eye (I know I've had trouble occasionally), here's a technique that works no matter what:
  1. Point the thumb of your right fist up, then rotate your wrist until the thumb points in the direction you want the screw to move (in or out).
  2. The direction your fingers curl indicates the direction you need to turn the screw.
This rule works regardless of your vantage point. For a left-handed thread, you would use the same technique, but with your left hand.
Honestly, that only has to do with whether you leave your ball mount in the receiver when not in use or not. With either style of truck (Cybertruck or traditional truck) you can leave the ball mount on or off without regard to whether it has a cover available or not.
