rlhamil
Richard
Glen Burnie, Maryland
Tank turn will destroy your tires on a parking lot. Like doing a 45 second burnout, really bad. If you are on a gravel road, it will damage the road surface and your tires both. Damage is comparable to doing a really tight donut. If I used tank turn to flip around when out doing trail work, the local forest manager would not be happy with me.
Having 4 wheel steering will be a huge game changer in parking lots… but I don’t see crab mode being that important. Crab mode moves you sideways. The problem you have in parking lots is generally not moving sideways, but turning 90 degrees. That’s just basic 4WS no crabs involved.
Crab mode might be interesting for parallel parking, but only if there is nobody in the stall behind where you want to park.
Thrust vectoring and 4 wheel steering are the interesting bits. Tank turn and crab walk are parlor tricks designed to showcase those features and of little practical value otherwise.
I can see that it would be bad if not done slowly; but slow enough, I don't see the problem, assuming it can be done slowly (should be possible with the amount of torque available). Should be better on wet pavement, which would both cool and slide a bit.
It'd be neat if left and right as well as front and back wheels could steer separately; then it could arrange the wheels in a diamond pattern, which would allow pivoting on a spot with something closer to rolling than grinding motion. :)
Chesapeake Beach, MD
'23 MYLR, FS Cyberbeast 280xx
I always wondered why a 4 motors version was not planned. Rivian boasted it. I think this time Elon wants to destroy the competitors. More insane things will be revealed for sure
Could it be that it will be easier getting power to both rear wheels with independent motors? It may simplify the manufacturing and will get rid of the differential back there for sure. I know, the electric motor is more expensive and weighs more. But, does it weigh THAT much more than the differential and associated axle parts? It could be that the electric motor saves almost enough weight to be a wash and could simplify assembly and parts cost to be a wash as well. Hmm... Got me to thinking.
The diamond pattern might help, but I still think it would require breaking traction which would be rough on the wheels. If it only works well on gravel or wet pavement, that’s a sure sign you are destroying gear.
Hope Tesla doesn‘t invest much in chasing it myself.
Having parked and owned 8 or 9 pickups through the years, mostly Fords, from F150 through F450, I can tell you the F450 that I had (with the mono-beam front end) was the tightest turning of the bunch despite being the largest and longest one including the 2018 F150 I drive now. Of all the features in all the trucks I had, that tight turning radius was the single best feature. I one time made a U-turn on a two-lane road at an intersection without getting off the pavement. Man, that thing would turn sharp. It made parking so much easier. Anyway, I'm really psyched about the 4-wheel steering and the associated crab-walk that goes with it. It'll be so much easier scootching it over in the garage as I park as close to one wall as I can get when backing in. Exciting times, these are!
Bill906
Wisconsin
Jeep
I used to practice in the snow in empty lots when I got another vehicle, so that if things got interesting on the road, I'd already know how it would react.
I also would do this. In vehicles pre-antilock brakes and pre-traction control it was very helpful. ABS and traction control took all the fun out of it.
In the right snow/ice covered parking lot, tank turn and skid steer would be a blast.
Throwcomputer
Staten Island, NY
TV & Film
Definitely did my fair share of this. We would also tie a rope to the hitch and grab a snowboard and whip people around the lot on their snowboards like they were wakeboarding. Fun times!
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
ABS made practicing safe, tho ^-^
Well... SafER.
Bad planning and poor execution can still trump ABS. And lots of parking lots have large poles in the middle for lights. Those concrete bases make for a very quick way to stop a slide or fun donut.
Throwcomputer
Staten Island, NY
TV & Film
Well... SafER.
My station wagon in high school had a nice dented rear fender from one of those pesky concrete bases. Jumped right up in front of me when I was doing donuts in reverse!
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
I once had a stone wall jump out and bite the front passenger side of my vehicle. That pesky wall was just not obeying the laws of physics for some reason. Had absolutely nothing to do with my emotional state resulting from a girlfriend breaking up with me minutes before the drive. Had even less to do with the fact I was driving somewhere I was completely unfamiliar with, at night, on a very curvy road, with dips, way too fast.
Crazy stone wall...
anionic1
Estimator
Tank turn and crab walk do nothing for me. You can keep them for parlor tricks.
Also sounds like more parts to maintain to me. Rear suspensions and breaks usually last a long time but with rear steering and even more power to those back wheels on a heavy vehicle that will definitely wear faster.
anionic1
Estimator
If the wheels don’t have to stay parallel it won’t be an issue. Like if the front right tire can turn towards 315 degrees and the front left turns 45 degrees and the rear does the opposite and wheels turn different direction from the right side of the car to the left it would be great. I am very curious how the back wheels get turned. It can’t be a rack and pinion type and mat be a turn by wire setup. I doubt they will have or are allowed to have wired servos do the turning.
anionic1
Estimator
The F-150 Lightnings that people actually take delivery of in the first year, most of them will be around $80K to over $90K with inferior specs to cheaper Cybertrucks. You lament higher prices without any confirmation from Tesla. Seems like you are putting the cart before the horse.
I am quoting about $2,000,000,000 in construction this year and it’s all going up at least 15%. There is no reason the CT would be exempt and all the other Tesla vehicles have gone up at least that much. It is going up.
To make such a statement you would need to know what kind of margins Tesla based the reservation prices on, what percent was materials costs and how important it is to them to sell initial production at a profit. They may have room to absorb the increase in the price of raw materials. Pricing in the auto business is quite a bit different from the construction industry. There is a good chance Tesla will honor the reservation prices and, if need be due to excessive inflation, raise them for new orders. That might be the reason Tesla stopped including price estimates with new reservations.
What I'm recommending is that you wait until Tesla reveals the pricing before claiming it has gone up for existing reservations. It might go up for new orders but not for existing reservations. In fact, Tesla has never refused to honor the reservation prices with other models and they are now in a stronger financial position than ever before.
Tesla vehicles went up because demand did. Not because costs went up.
If costs went up, profits per car would have gone down. They've gone up, instead.
Also, Tesla would have bought the majority of the raw materials before they announced the truck. Otherwise they couldn't guess the price accurately.
