Seatbelts installed backwards in back?
Virtualarry
Cybertruck & Model Y
Self Employed Investor
Anyones rear seatbelts installed backwards?
Mine seem it, twisted
Tesla Cybertruck Seatbelts installed backwards in back? imag
cybercoffee
MYLR
I believe my left one is the same way as yours, and the right one is the opposite. but I often have car seats in so I can't quite recall; that also means fewer adults are sitting back there who might otherwise be able to notice.
I did also notice that they twist easily when retracting (like if you're not careful and let it retract in quickly, it'll fold on itself and keep on rolling in as if nothing happened).
What does your right side look like?
HAL GALLUS
HAL
MN
MODLE 3
If that is the biggest problem your life then your doing pretty good.
TheLastStarfighter
Industrial Engineer
This forum isn't for life problems, it's for Cybertruck problems. If you are looking to discuss big life problems, you should head elsewhere.
sharpgator
Scott
Birmingham, AL
26 AWD CT, M3
Have you tried pulling it all the way out to see if it somehow got a twist in line when retracting back into the seat back?
Yes. Mine is installed wrong. There was a thread on this a while back. I think it takes a lengthy number of shop hours to fix.
Virtualarry
Virtualarry
both back belts are backwards
I will handle it in my next service in 2 weeks.
Also my floor creaks under the center console when i turn hopefully just loose bolt.
Virtualarry
Virtualarry
Yea absolutely... I was a beta tester for 2013 Model S. I rather this be me than a new Tesla Owner!
Virtualarry
Virtualarry
Yes tried that, no twists... only twists when you buckle up as it's backwards. Would this not be a recall? or just a silly assembly line mistake? Kinda like the few 90 degree rear door hinges that did not get installed?
Virtualarry
Virtualarry
Tesla website shows the buckles facing out, not hidden behind the belt.
Tesla Cybertruck Seatbelts installed backwards in back? tesla pic
