Slow charging
bosshog
roardog
canada
I have new cybertruck and with supercharging I never get more than 180kw when charging on a supercharger despite using a 250 KW super charger . Most instances its 120- 130 kw max . So charging times markedly increased .
This is despite pre conditioning , no blue light on battery etc
Is this potentially a battery issue or something else ?
jonesw67
Warren
AR
FS Cyberbeast
what percentage are you starting at, because that changes what you will see.
If you are below 30% (I think) you will see much higher charge speeds, then it curves off as it increases charge level
bosshog
roardog
canada
start at 20 -30% most times .
Better than 14.3
bosshog
roardog
canada
Thats very helpful to know. Still think charging speed is under that curve though
Mal
Mal
WA
Foundation CB "Rocinante"
Here's a pic of a recent charge session. I think we got there around 25% and were charging to 90% (to reach a hotel at ~80%). Anyway, it was doing 255kW for a bit.
Tesla Cybertruck Slow charging 1738623308659-m1
bosshog
roardog
canada
lol I have never even come close to that speed
ModelCYBR
Bring to service center. Either it’s a bad supercharger stall or something wrong with your truck
So you are navigating to the Supercharger to get that level of preconditioning (versus just running climate)? Your location says Canada and if the pack is cold (even if warm enough to not have the snowflake) it won't charge at full speed. You can read pack temperature from the service menu.
Also, 250kW is max possible, if all the posts are busy, it'll being be lower, but you would get a message saying charge rate is limited by equipment...
bosshog
roardog
canada
Ok thanks . It’s been so far a warm winter . I will look at the service menu and see the pack temp .
bosshog
roardog
canada
I run pre conditioning prior to charging .
Lasttoy
Paul
St Augustine, FL
I've been on 1 3500 mile trip, 6 600 mile trips. Charged at a lot of 250kw stations. None, none have ever gone over 200. Rate of charge is determined by cars BMS. I've been near zero miles. Still not charging over 200. The 4680 battery seems not to like power jam. I have 15000 miles on it. Still will not go over 200.
problem
Kratos
crawmancyber
engineer
Nope i used the latest v4 charger and it went pretty fast..
Tesla Cybertruck Slow charging WhatsApp Image 2025-02-04 at 14.04.38_b9c269ec
