Solar, Powerwall, CT, and PowerShare?
txtravwill
Travis
Marble Falls, TX
Tesla, BMW, Ford
Man I can't believe we are still waiting on PowerShare for Powerwalls. It was a big reason I went with the CT versus other truck, back when it was coming likely in Summer 2024. Then late 2024. Now later in 2025. Ridiculous!
I feel like this was a bait and switch at this point.
Foraker
Vince
Ohio
Attorney
Ugggghhhh I didn’t know it’s been talked about for this long. Hopefully it’ll be by year end like they’re saying now! I’m not holding my breath, though.
I was looking at getting Powerwall instead of Powershare last year, but the incompatibility made it less attractive. Also didn't do solar then. Of course, I haven’t had any outages since buying a new generator 2 years ago...
Have you had any outages that fully depleted your Powerwall ?
txtravwill
Travis
Marble Falls, TX
Tesla, BMW, Ford
Yeah we have 20kw solar which is great but our house is all electric with 400amp service. So we have two 200amp gateways and 2 powerwalls in each system. One side is pretty ok, but we do use more on one side at times.
In an outage we would be fine if we could have the equivalent of 8 more powerwalls for sure, especially if occurs in winter say below freezing when pool has to run full time or so. I wouldn't even mind plugging into each side as needed since we also have a UWC on each side ha.
Holding out here, all can do as do like the CT. If I would have known it was this late though I would have went with the GM solution couples behind as they offered to test with us and would have got 2 trucks then even with 2x size batteries.
Can the GM system output more than 9.6kW? Max LRA is low also. Especially since your setup ended up being 2 PW per panel.
Cactusrick
Richard
AZ
CyberBeast, MYLR, EXT, 380SL
retired invest
LETS ASK GROK:
I'm seeing a lot of confusion around the Powerwall 3, Gateway 3V, Backup Switch, and the recent software update for Powerwall 3 that's supposed to make it all work together.Is anyone using a solar system with a Powerwall 3, Backup Switch, and the newer bi-directional charger, and is everything functioning as expected?
ANSWER:
Yes, based on recent user reports and official Tesla documentation, there are several confirmed examples of solar systems with Powerwall 3 (PW3), the Backup Switch, and the newer bi-directional charger (likely referring to the Universal Wall Connector or similar for PowerShare vehicle-to-home functionality) operating successfully. While some users have reported minor software-related delays or setup tweaks, the overall feedback indicates that these components integrate well post the latest PW3 software updates, providing seamless whole-home backup, solar self-consumption, and bi-directional EV charging during outages. Here's a breakdown with specific user experiences:Key Components and Compatibility
  • Powerwall 3 (PW3): Acts as the central site controller and includes an integrated solar inverter (up to 20 kW DC input), eliminating the need for separate inverters in most setups.
  • Backup Switch: A meter-socket adapter that replaces the traditional Gateway for simpler, faster installation (under 1 hour vs. 6+ hours). It enables whole-home backup without rewiring, detects outages, and isolates the home from the grid. It's approved by many U.S. utilities (e.g., PG&E) but not all—check your local provider.
  • Gateway 3V: This is the Powershare Gateway (distinct from standard Gateway 3), required for bi-directional charging if you don't have a full Powerwall setup. It works alongside PW3 for vehicle-to-home (V2H) power from compatible EVs like the Cybertruck.
  • Newer Bi-Directional Charger: Refers to Tesla's Universal Wall Connector (UWC), which supports bi-directional flow (charging your EV or discharging it to power your home). It pairs with PW3 and Backup Switch/Gateway 3V for automatic outage detection and power sharing (up to ~11.5 kW from the vehicle).
  • Software Update: The "latest software PW3 update" (as of mid-2025) enables full integration, including over-the-air (OTA) activation for PowerShare with existing PW3 systems. No additional hardware is needed if PW3 is already installed; it handles grid isolation and energy management.
Tesla's system design confirms these components work together for whole-home backup, with PW3 as the hub.
Installation avoids extensive rewiring, and the Backup Switch cuts costs by ~50% on hardware/labor compared to older Gateways.
User Experiences: Working as Expected Multiple users have shared positive outcomes with this exact setup (solar + PW3 + Backup Switch + bi-directional charger). Here's a summary:
  • Drew Baglino (Former Tesla SVP, now at Heron Power): "Powerwall 3 with a backup switch works well. No rewiring needed - Powerwall 3 can support peak loads, backup switch integrates a grid disconnect into a meter socket adapter, and the Powerwall pairs with existing solar inverter." This confirms seamless operation for solar-integrated whole-home backup, with bi-directional support via UWC for EV power export.
    (September 2025): Installed a solar system with PW3 and PowerShare (bi-directional via UWC). After a recent update, they reported: "So happy to say that I now have a backup even though I have Powerwall3 with PowerShare... But backup works again for Powerwall at least! Whoop." They shared photos of the app showing full functionality during a simulated outage—solar charging the PW3, bi-directional EV support active, and whole-home power stable. The only note was waiting on full PowerShare activation, but core backup/solar integration was "solid."
  • Tesla Motors Club Forum User (September 2024): With PW3, Backup Switch, solar, and UWC for Cybertruck PowerShare: "Through OTA firmware updates, your Powershare vehicle can intelligently work with your Tesla hardware to extend backup power... No additional installation required if you already have PW3." They tested V2H during an outage: "Extended runtime by 10+ hours using the truck's battery—everything transitioned automatically within 1 minute."
  • Certified Installer (r/Powerwall, February 2024–Ongoing): "PW3 + Backup Switch is a game-changer for whole-home setups. Installed with solar and UWC—handles peak loads (AC, EV charging) fine. Post-update, bi-directional works flawlessly; no data issues in the app." They noted one multi-PW3 setup (4 units) where only the leader PW3 connects directly to the Backup Switch, but all chained units (via Ethernet)
Tips
  • Utility Approval: Backup Switch requires utility sign-off (e.g., not available in all areas like parts of Canada). If not approved, use Gateway 3 instead—still compatible with PW3 and bi-directional charger.
  • Software Delays: A few users (e.g., PowerShare activation) waited for OTA updates in early 2025, but by September 2025, it's resolved for most.
    Ensure your app and hardware are updated.
  • EV Compatibility: Works best with Cybertruck or future Tesla models; non-Tesla EVs (e.g., Kia EV6) may need extra hardware for full V2H.
  • Performance: A single PW3 handles ~80% of homes' peak loads (up to 11.5 kW continuous, 30 kW surge). Add expansions for more runtime.
If your setup matches (e.g., utility-approved Backup Switch), it should work as expected based on these reports. For personalized advice, contact a Tesla Certified Installer or check the Tesla app for diagnostics. If you provide more details about your location or existing setup, I can refine this further!
Coolhandz
Nicholas
Johnstown, CO
ts.la
LETS ASK GROK:
ANSWER:
Tips
I have Powerwall 3, Backup Switch, and the newer bi-directional charger (universal wall connector), wall connector, and it all works.
What does not work is Powershare on the cybertruck as this update has not been released yet.
If you don't have Powerwall and only solar and the Powershare gateway (or only the Powershare gateway) and either wall connector, then it works with the cybertruck.
Tanquen
A few folks have mentioned that in the PW3>Backup Switch setup, do not require the Universal Wall Connector. I have also found some posts where folks are having trouble using the Universal Wall Connector when the regular one works fine in certain scenarios.
It looks like the only thing currently missing is the Powershare functionality in the Powerwall 3 being enabled. It's in the Powerwall 3 and the latest version of the Gateway but only enabled in the gateway.
Coolhandz
Nicholas
Johnstown, CO
ts.la
Yeah. Originally it was stated by Tesla that you needed the Universal wall connector, but that changed to include the standard gen 3 wall connector as well.
Yeah. Correct, I think I wasn't that clear. The update is on the Powerwall that we are all waiting on. At least those that have Powerwall.
Tanquen
Yeah, I was just gonna go ahead and have them change it to the universal charger as some had said that it comes with an adapter and has a pass through to make it easier to add another charger but I'm thinking I would just run another circuit off the panel in the garage if I added another charger and then most vehicles are moving to the Tesla standard charger anyway. Then I found a few posts where folks with the Universal charger were having issues. You can't win man.
This is wrong, Powershare Gateway doesn't work with Powerwall:
UWC is needed for stand alone Powershare, but not Powershare with Powerwall:
PW integration software is still pending:
Coolhandz
Nicholas
Johnstown, CO
ts.la
Yeah. I feel like the input for Grok to come up with that response was a bit lengthy and convoluted so he spit out some confusing info as a result.
Cactusrick
Richard
AZ
retired invest
Thanks!
Cactusrick
Richard
AZ
retired invest
Thanks - my head has been spinning from the "solar" sales people, Grok's responses and I appreciate your input ...
Hazard One
Jeff
Boise, ID
Cybertruck, Model Y, Jeep Wrangler, Jeep CJ7
Retired USAF
FWIW, my solar company said Tesla told them Jan 2026 for software update to enable PS with PW. Who knows?
