Stainless tailgate cap and sail panels
EMoeller
Eric
West Marin, California
Porsches (992 Turbo S, 993 Turbo, 993 Targa)
Geologist
Sail panels will be secured using roof rack studs.. and stainless Rivnuts... the tailgate cap will be secured to 4 threaded holes on the inside lip of the tailgate that are revealed when plastic cap is removed... for the sail panels this means if your gonna run a roof rack the panels would need to be removed revealing the plastic ones underneath. This is version 1.0 there probably will be a better solution for using the roof rack down the road...
Installation of these pieces will require removing the little trap doors on the sail panels. Simple to do just open half way and then pry out one end with a very small flat head screwdriver. Tailgate cap will also need to be popped off. Mostly this can be done by hand but maybe a flathead screwdriver would make it easier..
I was all in on this until this post. Those "trap doors" are for mounting my crossbars, so eliminating those is a deal breaker for me. I'll follow along and perhaps a later iteration will work for me.
Lowcoe
Lowcoe
Erich
S3xY
Gardner
Yeah won’t work with tesla style roof racks. I’m sure a special request could be made for the area over the trap doors to be cut out so stock roof racks could be used but then you would need some other solution to attach the sail panels if you weren’t running your particular rack. Life is always a series of choices.
PungoteagueDave
David
Boynton Beach
I see diminishing returns here with a very limited use case. Beside being quite expensive, they are stainless steel, add to the vehicle weight up high, and would scratch if used to carry wood or actually protect the vehicle. Seems to me that the sacrificial plastic material that’s already there could be replaced a few times before paying for this setup. And it honestly looks amateurish.
PungoteagueDave
David
Boynton Beach
Then don’t buy em Dave. Go take a seat in your armchair and keep on typing out your brilliant comments while other people put in the work.
Just pointing out the obvious. People buy the lamest stuff just because it exists. Try to make the case.
mcm4ss
Matt
Oregon
Cybertruck and 7 others
Landscaper
since the bolts hold those on and the cross bars attach over the plastic would not the cross bars be able to hold those down? Could you cut out those openings for cross bars and add a "plate" to cover those holes with bolts going to the factory hold downs? That way I could use my rack and factory holes but still have the ability to cover them up with a simple plate?
mcm4ss
Matt
Oregon
Landscaper
I've built many a product with Aluminium ( ALU_MIN_UM ) 'CHECKER' plate and it usually ends up BAD like Michael Jackson's : WHO'S BAD!?!?!
yeah, My diamond plate looks like shit. Gave up. Don't have the way to do what Jasper is doing. I will buy a set soon.
Lowcoe
Lowcoe
Erich
S3xY
Gardner
Yes , that would work, whatever plate was used to hold down the panels would slightly take away from the clean lines and would be criticized by others but it definitely could be done.. I’ll talk to Jasper about it.
Lowcoe
Lowcoe
Erich
S3xY
Gardner
Hoping to get this done soon. Life keeps getting in the way. Hopefully I’ll have my finished set on the truck in 2-4 weeks… In the meantime….
Tesla Cybertruck Stainless tailgate cap and sail panels IMG_6100
Tesla Cybertruck Stainless tailgate cap and sail panels IMG_6092
TwiztOG43
Las Vegas
Tesla Model Y Performance, Tesla Model Y LR
btcrealm
Brian
Virginia-ish, USA
cybertruck
NOC
I have a pre-order with Cyberrak for their “Full Rack + Toolboxes and Enclosure”
They were very responsive with my questions and updates.From their website they already have some prototypes.
I've put in a preorder as well. They are in NC so I plan on driving down when the are available. Its refundable so I'm not too worried if they don't actually work out (wait... the cybertruck was refundable too.... *facepalm*). I'm only interested in the full size rack with no panels or boxes.
Based on what I've read and talking to them I think this solution will be the easiest to unbolt and lift into garage rafters when not needed. My primary reason for this one. The stainless didn't hurt it either ; P
The actual on vehicle pictures weren't around when I preordered. The new extra bar on top is interesting.
btcrealm
Brian
Virginia-ish, USA
cybertruck
NOC
Ok I pinned Jasper down on pricing.
Will be sold as follows
1. Tailgate cover and 2 Lower Sail Panels plus any necessary hardware. $1600
2. Tailgate cover alone. $550
3. Add lower sail panels later $550 each
4. Add upper sail panels above doors. $300 each.
Pricing does not include tax or shipping.
This will be top notch quality. All seams will be TIG welded and metal finish will mimic original Tesla metal finish. Made in America
He is now taking deposits of 50% first come first served. Should be at your door in 4 weeks from order.
email [email protected]
I'm actually very interested in the tailgate cover. Is there a place to look at install instructions? Not sure how this piece connects to the tailgate.
Thanks
Lowcoe
Lowcoe
Erich
S3xY
Gardner
Thanks
It’s not rocket science. Just pry off the existing cap with a flat screwdriver, inside lip has 4 or 5 torx screws that you remove. Same screws are used to secure new stainless cap in place…The stainless tailgate cover is very robust.. Pretty cool as a stand alone piece. Upper and lower sail panels would add lots more to the clean look.. Tesla should have done this….
