Loudness
Jay
Atlanta
Cybertruck (AWD)
Are you running the cable behind the rear seats and under the floormat?
I'm running it under the rear ceiling trim and down the outside of the passenger seat, tucked behind my seat cover, then under the rear seat and under the aftermarket underseat storage and rubber floor mats.
Other than the short bit across the glass to the trim and the tiny bit you see to the AC outlet, it's completely invisible.
4 SPACE
Chuck
Bullhead City
Cyber Beast (Foundation Series) Model Y (Juniper)
Here is my version of the ultimate Starlink mount.
Quick and easy removal if needed. Just waiting for a short 3ft power supply I ordered. plugs into bed outlets. No body parts had to be removed. I do need to make a slight angle adjustment, so it follows body lines exactly
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 20251022_164109
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 20251022_164127
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 20251022_163959
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 20251022_163852
I love this
4 SPACE
Chuck
Bullhead City
Thanks the only thing I guess is the bed outlets don't work while at home on lever 2 charger. But I don't need it while I'm at home. But the quick disconnect by either the star link mount or by the slotted screws is great. Plus, it just plugs in right there.
Hookalakupua
J
Reno/Bay Area
Placed an order for this earlier today. Needed an option to use the Starlink when deep in the backcountry away from the CT. It also solves a power issue I was having as couldn’t figure out a perfect solution, given my needs. Not sure how I’m exactly going to mount it, so still need to work that out but I have some ideas. 🤪
https://ravion.us/products/ravion-b...y51IYS_YEo_ZdlJ3zpwNaMn0FWWY0qgBoCvMMQAvD_BwE
I love the idea of both of those. OP, I generally keep a power bank in my vault for a ton of reasons. Those are really good for running g devices you want to keep running continuously even when you’re level 2 charging like a fridge or Starlink and charge very rapidly off the bed plug every time you get in the car.
Tesla Cybertruck Starlink: The Ultimate Mount Solution! IMG_6465
Vladimer
Steve
Virginia
2024 FS CB, 2018 MS 100D
Just got the invite from Starlink for the free mini, so now looking at CT mount solutions. This seems so elegant and simple if you can stomach the risk of someone taking it while you're in the restroom.
Is there a link? Where did you get this?
They are giving away the mini for free?
Jabman
New Jersey
Tesla Model S, Ram 1500
On a side note: Love the garage! And that floor is sick. Epoxy?
4 SPACE
Chuck
Bullhead City
Starlink sales the flush mount kit that I bolted on to the 3" bracket. That bracket just has 105-degree bend, and I drilled and tapped the tailgate. it can be removed pretty quick but you do need the Allen-wrench supplied with the mount, so it has some anti-thief. I would probably only remove it if I'm in a really bad area which I try to stay out of, I would be more worried about physical damage than getting the dish stolen at that point.
LivinLrge
Matt
Palm Beach
Cyberbeast, M4 Comp, Model 3 Plaid
Entrepreneur
I've got a better solution, no wires visible, factory equiptment only and combined it with a rear camera that gives you a great field of view and ability to pan down to be a bed monitor, hooked up to the wolfbox 850 up front.
I havent had time to write up the entire thing but here is a finished install on my truck. Ill post it up soon with how I did it. $0 in extra parts, only patience required on factory tesla cross bars.
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 17623654483955146743032765054345
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 17623654264995266610628405339076
Tesla Cybertruck Starlink: The Ultimate Mount Solution! 17623654820013198386993566839225
