Tonneau Cover Weather Seals In between SLATS coming undone
The Tesla Guy
Daniel
Washington
youtubeteslaguy.com
maybe spray some WD-40 to lubricate the rubber seals so you can move them? I will try everything I can to fix it before sending it to service center ....
Absolutely take it to the Service Center.
There may already be a service bulletin. If not, there needs to be one so they can be made aware of this issue as soon as possible so it can be resolved for existing and new vehicles. Definitely not a DIY situation.
edc
edc
C
Tesla Model X, Y, Cybertruck
Yeah man sucks.. I'll update you guys on how long it's going to take.
Pialot
Jeff
Litigation Management
By chance does the ceramic coating assist or hinder the seal at all? I was considering getting the full body coat
edc
edc
C
may help coat it to prevent UV damage but you can do much cheaper stuff like 303 aerospace protectant
also not sure if will damage the rubber. usually not supposed to apply ceramic coating to rubber
Dazureus
US
'21 Model Y, '24 Cyberbeast
Model X ppl have been using Gummi Pflege Stift on window and falcon wing door seals with good results. Maybe it will also work well with the tonneau.
jf64k
Interesting (to me anyway, haha!!) that’s the brand of foam A/C cleaner that Tesla SC’s use to clean the A/C in M3 and MY.
nextzett 96110515 Klima-Cleaner Air Conditioner Cleaner - 10 fl oz https://a.co/d/1TD7qqb
Stuck4ger
Cape Canaveral, FL
Aerospace
I think you'd want to try the silicone lubricant version, not regular WD-40.
Tesla Cybertruck Tonneau Cover Weather Seals In between SLATS coming undone 1661734744-30001-silicone-11oz-front-min
Lowcoe
Erich
S3xY
Gardner
Searched Tonneau found this thread... maybe opened 20 times and now this.....
Tesla Cybertruck Tonneau Cover Weather Seals In between SLATS coming undone IMG_3543
tried to push it back in but just pops back out....
Tesla Cybertruck Tonneau Cover Weather Seals In between SLATS coming undone IMG_3540
edc
edc
C
dang. So I'm not the only one. My appt is next week so we'll see what they say and how long it takes.
lowtek
Here
None
WD40 is not a lubricant, try silicone spray.
I've had my Cybertruck 48 days and I estimate I average 5 openings/closing per day, so over 200 open/close cycles. Just checked my seals and all are within 1-2 mm of being centered, left to right, probably normal assembly tolerance.
My theory is tonneau covers with creeping seals are not rolling up square to the roll for some reason, probably installed out of alignment or something, so that the seals gradually walk to one side. I think if a tonneau makes it this long without the seals creeping, they are probably stuck in place and there won't be an issue.
Definitely a job for Tesla to fix.
Reactions: Mal
Stuck4ger
Cape Canaveral, FL
Aerospace
I agree and would look for warning signs of one side leading the other when moving. If that is happening then get it calibrated or fixed before the seals begin creeping and you start opening up gaps.
M0unt41nm4n
Durango, CO and Moab, UT
Yes... use 303. It's made for rubber (I use it on my rafts). It protects against UV... it will not damage rubber. It's made specifically for that. I wouldn't use anything else.
cybercuh
Ben
IE
AWD CT VIN 50XX
Same as mine... appt is for late next week :(
N800AN
Jeff
DFW
Volvo, VW, Ford, Tesla
Had an appointment for May 31st, but Tesla Service just notified me due to parts supply they've rescheduled..... to July 18th! Totally insane, and tonneau slat seals just keep getting worse with each mile. I'm ready to dump this thing.
