Dogger37
donny
PA
Can you take a side profile pic of the truck so we can get a good look at the tires in medium height?
Thanks,
Donny
mts678
Marshall
Dallas
Cybertruck Foundation
Consultant/ Public Adjuster
Medium height. I cut the tip off the stud
Tesla Cybertruck Toyo AT3 EV tires (285/70/r20) installed IMG_2857
Tesla Cybertruck Toyo AT3 EV tires (285/70/r20) installed IMG_2856
shopaholic
Gee
East Bay
Those of you running on Toyo AT3s give an update on EV efficiency numbers please?
CallsignVega
Cybertruck, Brightdrop 600
Yep
Overall diameter: ~ 2.1 inches taller (36.7” vs 34.6”)
• Sidewall height: ~ 0.56 inches taller per side
• Circumference: about 6% larger
• Speedometer impact: When your speedometer reads 60 mph, you’d actually be going about 63.6 mph with the 285/70R20 tires.
Just a correction on your numbers; they are 35.7 inches tall, so 1.1 inches taller than stock, not 2.1.
3.1% larger circumference.
AT 70 MPH displayed you'd be going 72.2 MPH. For efficiency calculations, you have to reduce 3.1% from the Toyo watt hours to compare versus stock. So Toyo tires around ~15Wh more efficient than the Cybertruck is displaying.
I ordered these as they tick all the boxes I'm looking for:
1. Decent off-road tread.
2. EV specific.
3. Slightly larger than OEM.
4. Definitely more aggressive look.
5. 3-Peak snow rated.
Doing some measurements, since they are just a hair over 1/2" sidewall height taller than OEM, you shouldn't have to cut the tip off the upper ball joint bolt or make any modifications.
Cyberskunk
Patrick
Minnesoata
2025 AWD CT, 2020 3 LR AWD
Tech
2. EV specific.
You don't have to cut the tip but... If you off road with reduced pressure I would.
CallsignVega
So just got these bad boys put on.. van charging Cybertruck for the 1.5 hour drive to the tire shop:
Tesla Cybertruck Toyo AT3 EV tires (285/70/r20) installed signal-2026-04-27-072114_002
Off with the Pirelli's:
Tesla Cybertruck Toyo AT3 EV tires (285/70/r20) installed signal-2026-04-27-160947_002
New S3xy:
Tesla Cybertruck Toyo AT3 EV tires (285/70/r20) installed signal-2026-04-27-165729_002
Tesla Cybertruck Toyo AT3 EV tires (285/70/r20) installed signal-2026-04-27-165729_003
Some random thoughts:
1. I was left with about a 3/8th's of an inch gap between the front tires and the bottom of the stock upper ball joint bolt. I'm comfortable with this but will double check any touching when I air down the tires for off-roading.
2. The tires are noticeably louder than the OEM Pirelli's, but not anything intrusive. I can hear the front tires much more than the rear for obvious reasons.
3. The truck looks WAY better with these tires.
4. I thought maybe they would be more comfortable of a ride having slightly over a half an inch more sidewall. But I think the stiffer/beefier sidewall for off-roading negates all that and the OEM Perelli's ride a little more comfortable.
5. I wasn't able to get any accurate energy use differences on the drive home as the wind was howling.
6. No rubbing even on the "low" suspension setting lock-to-lock.
7. Not a cheap install; doing the five tires including a full size spare, was right at $3,000. Actually had to pay a disposal fee for the Pirelli's with only 2K miles on them. I'm rural and didn't want to lug around four tires for the off-chance I'd be able to sell a Cybertruck specific tire set.
8. I'm glad that I can now off-road, but with comfort also high on my list after experiencing these 20" wheel/36" tires I'd probably lean towards aftermarket 18" wheels and making 37" tires fit with proper-offsets or small wheel spacers and slight wheel well mods.
I may drop the Toyo's pressure down to 45PSI to see if maybe I can get a little more flex out of them.
rnpvenom
BC
Model Y, CT
I’m glad you had a good result! I’m stilll super happy with mine and it’s great to see others weighing in. As it sits now, if I had to get new tires again tomorrow, I’d buy the same ones again for sure.
shopaholic
Gee
East Bay
I see the Toyo and Tire rack show LT285/65/20’s available. Any specific reason the members are upsizing?
