Upgraded order from dual to tri motor!
Daweism
Dawei
2014 Ford Raptor (Supercab)
Tech
I wonder if by configuration time there will be a "Plaid" performance package. Another $10k to the cost no doubt, but we can hope it comes standard with the Tri Motor to justify the $20k price jump from Dual to Tri, whilst Single to Dual is only a $10k jump.
CyberMoose
i don't think it will be included with the trimotor. The trimotor might be a 20k jump but it's also a 200 mile range increase and also incredible performance.
Daweism
Dawei
Tech
Whatever they do... I'm compulsd to configure the fastest CT.
Red61224
Yugo
I upgraded mine yesterday to dual motor. I have a class C RV now, when I get the CT, I'll sell my motorhome and buy a travel trailer. What kind of travel trailers people here plan to tow with their CT?
And it comes with a guest bedroom for when the inlaws drop in for a visit.
Tesla Cybertruck Upgraded order from dual to tri motor! 1598495675364
Red61224
Yugo
Well single motor was supposed to be first, but thankfully with the much much higher demand for tri/dual motor options, Tri motor will be first, then dual, then single.
Have two Tri Motors on reserve, 1st at 123,xxx pole position, and the 2nd at 359,xxx, just because. Maybe as an "investment"........
CyberMoose
I have no doubt that a Quad Motor version is coming.
Maybe but i'm not an expert in automotives or the technology that's in a Tesla. Sure the difference between the Dual Motor and Tri Motor options is pretty big but how much of a difference will there be between tri/quad. Towing capacity could be limited by other factors, acceleration and speed might only have slight increases and i don't even know if the range would be better or worse.
Sure if they had a Quad motor option you could do the tank turn like the Rivian R1T, but lets be honest, that's fun for a little while and then you just do it to show off to people who haven't seen it. I'll just find someone with a Rivian and do it a couple times.
I would really just want a quad motor if they can increase that 0-60 a little more. I know it's already amazing for a truck and will beat the majority of cars out there, but every little bit extra, i will love.
Reactions: TAG
Planet Earth
I find it interesting that the EV GMC Hummer pickup will also offer single, dual and Tri motor versions. Let the EV pickup wars commence!
CyberMoose
Well I think the Cybertruck shows the performance and utility increase that you can get between those motors. I'm actually more interested in Rivians reason for a Quad Motor. The Rivian R1T (and even R1S) have Quad Motors but they don't out perform the listed specs for the Tri Motor Cybertruck. I know that we haven't seen that Cybertruck yet but I have confidence that Tesla will deliver on the performance.
So is the 4th motor really needed? Not all motors on other Teslas are the same so maybe the Rivian will do the same and put weaker motors in the front and stronger in the back. Other than that, there are benefits to having a quad motor but I wonder if it's really worth putting it in.
I wish a company could do single/dual/tri/quad motor options so we could the the specs change between all 4 options.
Planet Earth
I can see Tesla offering a quad motor option after the 2nd or 3rd year of production. I would be willing to bet that the exoskeleton is being designed/engineered to accept a 4th electric motor.
ELCTRUK
Ray
Wylie, TX
www.elctruk.com
Cybertruck Tri Motor AWD w/FSD
Funny, I did the same thing today. I did it because I wanted the extra range for back country exploring. I also added the full self driving. In the specs with the tri motor it said that auto pilot was standard. I assume that the full self driving is not auto pilot. It that correct?
That’s correct. ??
Rivian and Lordstown are using the four motors to use lighter, independently controlled propulsion, which means no need for a differential.
Planet Earth
Rivian will be using inboard mounted electric motors (quad) at each wheel with a single speed gearbox.
Tesla Cybertruck Upgraded order from dual to tri motor! 1019F9BB-B208-4F02-A96A-0778570DC9A4
The Lordstown Endurance pickup will be using quad in-wheel electric motors. One obstacle is the additional unsprung mass of in-wheel motors, which makes tuning ride and handling more difficult. The in-wheel motors also need to be tough, as they can take quite a pounding on rough surfaces. Note that the rear suspension uses leaf springs. It does eliminate the need for CV axles however.
Tesla Cybertruck Upgraded order from dual to tri motor! AD30B13A-9A89-4EE6-A42B-7A11947B0D1C
People complain about the unsprung weight of the hubmotors but they're not all that heavy compared to engines ^-^
Sirfun
Joe
Oxnard, California
Retired Sheet Metal Worker
That looks like it might make sense on a trailer, for regen. :ROFLMAO:
