Cyberus
- May 6, 2024
- California
- Cybertruck
Call me crazy, but I enjoy the way stainless looks with all its imperfections, including fingerprints.
Yes,Can you just use Sprayaway with no other car wash method at all?
you're crazy.Call me crazy, but I enjoy the way stainless looks with all its imperfections, including fingerprints.
It's worked for me so far (delivery on 05/30).Can you just use Sprayaway with no other car wash method at all?
Yeah, there's limits.Although pre-rinsing or doing a snow foam wash to remove as many particulates would make a lot of sense.
Yeah, that's just for things staining the metal specifically, such as rust or water spots.
Yes,Yeah, that's just for things staining the metal specifically, such as rust.
- But if it's grease, you'll want to use a degreaser;
- If it's paint you'd want to use something that can break it up or solve it;
- if it's salt you'd want to dissolve it in water;
- If it's mud, sand, or even rocks you'll want to flush it away without scratching;
- And if it's oil or fingerprints or bugs you just need something to foam them away, and Sprayaway does that.
Yeah, it's been mentioned on the forum a few times, tho.Yes,
Not regarding use of sprayway.
Just came across it in Tesla service DIY section and don’t recall seeing that info in the Cybertruck manual.
Just curious, but would those iron removers like Adams sells work on iron contamination? The ones that turn purple when it reacts with iron? Thinking aloud.Yeah, that's just for things staining the metal specifically, such as rust or water spots.
I suppose? I don't know them. Things like Iron-Out are good at breaking up calcium deposits, too, in ways simple acids won't, so I can see using other things.Just curious, but would those iron removers like Adams sells work on iron contamination? The ones that turn purple when it reacts with iron? Thinking aloud.
Try stainless steel and more by Aqua Armor. Sold on Amazon it's ceramic Sio2 infused stainless cleaner.Im still waiting on "the best" recommended sealant/coating.. DIYdetail metal or protectaclear, I dont want to have to wipe down my truck every day... Haven't even cleaned mine yet, once I hear online of an actual coating that is working great, then ill clean/coat
