SlegMD
Lexus
Medical
The air pulls in toward the seat, I think the improved airflow is the sensation of air rather than more, though I am sure it feels nice 👍
I typically run fairly hot but I am moderately satisfied with the seats, I typically have to reduce airflow in other vehicles overtime, CT does not require adjustment. Must be a lot of sweaty CT drivers out there
The only thing I can think of is, are there airbags in the seats? I was thinking more about the mass of the beads in an airbag deployed scenario, should work well also. Worth a try.
Airbag locations:
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think GUID-64C0AF54-0B7B-421E-A08E-AC97B0A63871-online-en-US
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think SmartSelect_20250818_092932_Firefox
Don't want anything wrapped around the side of the seat, headrest straps look fine
Was that person a double amputee?
This is a clip from Men In Black, the legs are poorly visible since the color table was reduced when the GIF was optimized.
Some people obviously use the wooden-bead covers, but I'm certain it would drive me mad.
That Beast Mode
Phil
New Jersey
I know what you meant, but when I read this all I pictured was someone getting into an accident and airbags deploy under them and ejects them through the massive windshield.
The BAW will catch them
TexasRaider
JR
Denton
Cybertruck + MS
Civil
I added a ventilated and heated seat cover to my 17MS in 2020 from Amazon. Still works to this day. They generally do the trick if pay a little extra for a highly reviewed cover. I am very surprised mine has lasted this long . . In Texas aka I keep it running 90% of the year.
Tesla Patriot
DFW Texas
Cybertruck AWD
My understanding is that seat cooling works not by exhausting air out the holes. If that were true my recent Model S wouldn't not have had excellent seat cooling. Instead, they presumably have airflow beneath the perforated surface that flows past the surface, and carries away and facilitate evaporative cooling of your lumber.
The Model S would be comfortable long term in air-conditiong season at the lowest setting, and at the highest setting would cool one down fast and need to be reduced in a few minutes.
Cybertruck is virtually non-existent in the seatback, except at the very top where not needed. At full blast one still gets and stays hot. Seat bottom gets barely cool at full blast.
This is a design defect that needs correcting.
You guys are all wrong; Tesla designed these to be fart extractors rather than wafters.
TheEther
TheEther
Kentucky
The 3D cushion I posted gives me 2x-3x the cooling/airflow mid-back which is what I was after.
espresso-drumbeat
Espresso
Here
Agreed cooling works by exhausting out of the holes, the cooler the air under the seat the cooler the ventilated fans pick up. The 3D cushion I posted gives me 2x-3x the cooling/airflow mid-back which is what I was after.
But that's not how cybertruck ventilation works on the seats - the air is pulled into the seat by a fan beneath it. Try it yourself: turn ventilation to max (3), put your hand under the seat from the back row and you will feel which direction the air is moving
or, light a match right above the cushion and watch the smoke gets sucked into the seat
TheEther
TheEther
Kentucky
There is information to support a vacuuming versus exhaust for the Tesla ventilated seat system in the Cybertruck. Haven't found a definitive source yet. Either way, my felt experience with the 3d cushions spacer is night and day better.
TheEther
TheEther
Kentucky
Seeing that in some other searches also. Thank you for the clarification!
