ShockAuto
Reid
Lebanon New Hampshire
shockautostyling.com
2021 Model S Plaid, Cybertruck AWD Configured
Vehicle Wrapper & Content Creator
I know a lot of you guys were waiting so long for this video so here it finally is:
koolio
Greater Boston, MA
Here's the full video:
So, this is the root cause and fix for the door rattling when it shuts. I hope Tesla has fixed this in the current builds of the Cybertruck...and has a fix for all of us where this is occurring.
My driver door now rattles...started maybe 2-3 months ago (got mine in December 2024). It's a little annoying but not enough for me to schedule a service appointment since I've read the current solution is to replace the entire door, which may not have the glue issue fixed.
ShockAuto
ShockAuto
Reid
I have no idea why the link was removed
good stuff! they will probably add some mastic to help with NVH.
ShockAuto
ShockAuto
Reid
Planet Earth
$49,900 DM reserved on 11/22/2019. $59k DM delivered 6/26/2026
I hope a production refinement at the factory has eliminated door rattles. This procedure should not be necessary on a $70k + vehicle.
speedstuff
El Dorado Hills
26 CT Beast, 24 FS CT Beast, 25 MSP, 23 C8 Z06, 22 GMC 2500HD
ecom
Good info, thank you.
I had both front doors replaced under warranty on my FSCB - in my case there was some delamination causing an internal support to rattle against the door skin. This was on a vin 39XXX - my SC said there was a run of them with this issue.
bosshog
roardog
canada
I had the same issue. Got the door replaced twice but ended up surrendering the truck last month.
got mine 06/24
I have the same problem . Vibration on driver door at high speeds . Checked tires balancing etc still happens and more pronounced with a crosswind . Suspect this is the issue . Did you have the same problem at high way speeds that made them replace the doors
bosshog
roardog
canada
Issue vibration at highway speeds ?
speedstuff
El Dorado Hills
ecom
No, it was a loose 'twang' sound when hitting the front door with the side of your fist.
Imagine a piece of flat metal making a vibration noise against another. I should have recorded the sound, but the tech at the SC tested the same way I did.
Side of the fist against the door should be a solid thud - any other sounds noticed then something came loose (usually the lamination of the two pieces according to the SC tech)
