- Oct 3, 2020
- Western Washington, USA
If you had bigger balls, you might have just let it run. At higher speeds the aerodynamic drag comes into equalibrium with the grade. What? There were corners? Oh, like I said, it might take bigger balls! ?You are probably correct in general, but I don't have that limitation on the 100kwh Model X compared to the 135 kWh R1T (same hill, same boat ModeL X never limits regen. I think it's more of a thermal limitation issue on the inverter/motor. Pretty lame really to force the use of brakes and its a little shocking when the regen doesn't kick in when you expect it to and you jump over to the brakes.
Seriously though, it's not considered a defect when an ICE vehicle doesn't have enough compression braking, and ICE vehicles require riding the brakes on even gentle grades when descending with a heavy load, but I'm sure you didn't have to ride the brakes as much as your typical ICE tow vehicle. The ability to regen is also affected by battery temperature. The batteries can take maximum regen power when they are about 90 degrees F.
All that said, it's interesting that your Model Y, with its smaller battery, provides more regen power. Are you sure the batteries/environmental temperatures were equivalent?
