Old Spice
Mars
25 miles wow that surprised me. 10% less consumption with tonneau closed.
Tesla Cybertruck's Closed Tonneau Adds 25 Miles of Range at 75 MPH
We tested the Cybertruck Beast with its roll-top bed cover open and closed at 75 mph and saw 10 percent less consumption when closed.
https://www.caranddriver.com/news/a60200909/2024-tesla-cybertruck-aerodynamics-affect-range-tests/
  • The 2024 Tesla Cybertruck is more aerodynamic than it looks, and it's roll-top tonneau cover plays an essential role.
  • We tested the Cybertruck with the top open and closed; the latter position provided a 10 percent improvement in consumption during our 75-mph steady state test.
  • Our tests show the Cybertruck's real-world range drops from 250 to 225 miles with the top open; driven at 65 mph with the top closed, we predict a range of 295 miles.
The Tesla Cybertruck is more friendly to the air than you might imagine. The front end was always going to be a challenge, but the prototype’s flat nose was changed to a subtly curved front panel that helps the air bend around the forward flanks. What’s more, the front flares have been carefully shaped to create a small, deliberate vortex that helps to further encourage the flow to bend smoothly around those abnormally sharp front corners. The prominent wiper acts like a fence that directs air over the top instead of allowing it to swirl down onto the driver’s window, so wind noise isn’t as turbulent as you might guess—for the driver, at least. Underneath, the Cybertruck's belly is much smoother than any ladder-framed truck could ever hope to be, with minimal openings and fairings to smooth the flow over the suspension’s lower control arms.
This content is imported from Third party. You may be able to find the same content in another format, or you may be able to find more information, at their web site.
Arguably the most surprising aspect about the Cybertruck's aerodynamics is how naturally well-suited the angular-looking aft end actually is. The rearmost flanks taper gently like some kind of raindrop, which is the most naturally aerodynamic shape. Thing is, the abrupt truncation at the tailgate is actually quite good aero-wise. Wunibald Kamm (of Kammback fame) once demonstrated that such an abrupt cut-off would essentially trick the majority of the air flowing over such a body into continuing on a laminar path, thereby reducing drag more than a smoothly rounded design might achieve.
Of course, the Cybertruck's roll-top tonneau cover is essential to all of this, so we conducted 75-mph steady state tests with the tonneau closed, open, and with the tonneau and tailgate open together to presumably create an exit for the air ā€œcapturedā€ by the exposed bed. We also wondered about the effect of the wheel caps, so we repeated our tonneau-closed runs with them off.
We tested the Cybertruck's 834-hp tri-motor Beast model on 35-inch all-terrain tires, and ran it in the configurations mentioned above around a 6.6-mile oval track so we could eliminate any wind effects, which would have been significant for straight-line testing because it was a very breezy day, and we reset and recorded the truck’s internal cumulative consumption meter as we passed by a fixed marker on the track. The meter outputs real-time consumption in watt-hours per mile to three digits, and we recast this number in kilowatt-hours per 100 miles, which is a more standard format of this consumption unit.
The result? Consumption averaged 58.3 kilowatt-hours per 100 miles with the tonneau closed versus 64.2 kWh/100 mi with it open. This 10 percent increase in consumption suggests our 250-mile range test result would have been 225 miles with the tonneau open. Opening the tailgate at this point didn’t represent a meaningful change, as that measured 64.0 kWh/100 mi. Meanwhile, running with the wheel covers removed and the tonneau closed amounted to a tiny loss of just 1.7 percent: 59.3 kWh/100 mi instead of 58.3 kWh/100 mi.
Aerodynamic drag obviously changes drastically with speed, so we repeated some of our runs at 65 mph. Consumption dropped from 58.3 kWh/100 miles to 49.3 with the tonneau closed. That's a 15.4 percent reduction in consumption that suggests a 65-mph range of some 295 miles. Velocity-related aero benefits are consistent across a range of configurations, so it’s no surprise that our 65-mph bed-exposed run improved by a similar 15.6 percent, consuming just 54.2 kWh/100 miles at 65 mph instead of 64.2 at 75 mph.
Moral of the story: run with the tonneau closed. It’s more efficient, and the visibility ā€œbenefitā€ of the inside rear-view mirror isn’t all it’s cracked up to be because the view is way too pinched and slot-like. The camera system does a better job, as it turns out. And if you can run a few mph slower, do that too if you want to further boost your available range.
scottf200
Western NC
X; immed family 3 & Y
Some related data (thread).
Tesla Cybertruck Tested: Cybertruck's Closed Tonneau Adds 25 Miles of Range at 75 MPH (by Car and Driver) AkNjJmi
Gigahorse
AWD
With the range being precious you have to decide between an extra 25 miles of range or ability to see out the rear view mirror and use the camera.
Think that will come down to personal preference, maybe driving around town and short trips leave it open for safety and visibility and then when on a long trip when you need the range close it up and keep the rear camera clean.
Cyberman
Adam
F150,F550, Escape
Cybercontractor
Thanks for real-world stats like this. Now the question is, what is mileage like with vault open , tailgate open? That should reduce drag by a bit!
You still don't understand EV range.
Almost Mars
Cheney, Washington
Tri motor Cybertruck on order, Model S Plaid
Today I made multiple trips with the bed open. I don’t know or care about range for daily driving, there is plenty. I will do my best to keep the bed closed on long hauls. That’s not always possible with gear.
Tesla Cybertruck Tested: Cybertruck's Closed Tonneau Adds 25 Miles of Range at 75 MPH (by Car and Driver) IMG_5142
Tesla Cybertruck Tested: Cybertruck's Closed Tonneau Adds 25 Miles of Range at 75 MPH (by Car and Driver) IMG_5141
Gigahorse
AWD
Using a truck like a truck!
Scratches inbound, and that is not a bad thing!
Lug nut covers look good by the way
You are indeed seeing that once the vehicle range passes something like 200 miles, it really doesn't matter anymore.
DumpsterFire
Utah
Mouth Breather
Don’t want to say it but…..Duh!
Any real truck owner has known this fact for decades. There is an air bubble on a ICE truck that is created at high speeds but it’s still limited.
But if you add a bed cover and wow?!
Better aerodynamics! lol.
But you still said it… ?
Lots of people here that aren’t ā€œreal truck owners.ā€
Turns out there’s information out there that may not be important to you but might be important to others?
BlueLightning
Thomas
Oklahoma
Retired USA, Army
Very true, my apologies to all. Keep them covers closed.
Knucklehead
Mike
Virginia
Mustang Mach-e, Jeep GC-L, VW Jetta
It matters to me, on a trip away from home. I don't like being forced to stop every 200 miles.
