Old Spice
Mars
Source: https://github.com/teslamotors/custom-wraps
Custom Wrap Images for Tesla Cybertruck
Welcome to the Cybertruck Custom Wrap Images guide! This page will walk you through the steps to create and load custom wrap images onto your Tesla's 3D car visualization.
Getting Started
To get started, you'll need to download the template image provided below. This template will give you guidelines on how to generate new wrap images. To use it, fill in the white parts of the template with the desired content, save it into a file and follow the steps below.
Tesla Cybertruck How to: Create and load your Cybertruck custom wrap images onto your Tesla's 3D car visualization (instructions) templat
You can find some examples under example/cybertruck.
Image Requirements
To ensure that your wrap images work correctly, please follow these guidelines:
  • Resolution: Images must be 1024x768 pixels.
  • File Size: Images must be no larger than 1 MB.
  • File Name: Image names cannot contain special symbols and should be no longer than 30 characters.
  • File Format: Images must be in PNG format.
  • File Count: Up to 10 images can be used at a time.
Loading Images onto a USB Drive
To use your wrap images you need to load them onto a USB drive:
  1. Create a folder called Wraps at the root level of the USB drive.
  2. Place your wrap images inside the Wraps folder.
  3. Ensure that the USB drive is formatted as one of the following:
    • exFAT
    • FAT 32 (for Windows)
    • MS-DOS FAT (for Mac)
    • ext3
    • ext4
    • Note: NTFS is not currently supported
  4. Make sure the USB drive does not contain any map update or firmware update files.
Applying Wrap Images to Your Cybertruck
To apply a wrap image to your Cybertruck visualization, follow these steps:
  1. Plug the USB drive into your truck's USB port.
  2. Navigate to Toybox -> Paint Shop.
  3. Switch to the Wraps tab.
  4. Select a wrap image from the list.
  5. Tap on the wrap image to apply it to the car visualization.
Tesla Cybertruck How to: Create and load your Cybertruck custom wrap images onto your Tesla's 3D car visualization (instructions) paint-shop-wraps
Troubleshooting
If you encounter any issues with loading or applying wrap images, please check the following:
  • Ensure that the USB drive is formatted correctly and does not contain any map update or firmware update files.
  • Verify that the wrap images meet the requirements listed above.
mikeg112
Bay Area, CA
Model Y, Cybertruck
Will this work with 2024.39.5? I tried it with the instructions as exactly above but it doesn’t work, even with loaded example wrap files and creating a dedicated root folder
192.168.1.1
Tyler
2010 Ford Raptor, 2024 Tesla Cybertruck
Real Estate
Does the Drive need to be partitioned? Or can it be the same drive with the dash camera files?
mikeg112
Bay Area, CA
Model Y, Cybertruck
I did it as a separate drive partition so I can keep separate my music, Teslacam and boombox folders all separate. Surprisingly my boombox now works correctly for shows
192.168.1.1
Tyler
Real Estate
Can you give me list of drives you have on your partition?
I.E. Partition #1 - Tesla drive (#GB)
partition #2 - Boombox (#GB) - ETC
That would be helpful that way I don't have to keep reformatting my drive every time I wanna add a new partition.
mikeg112
Bay Area, CA
Model Y, Cybertruck
Oh sure, here’s the partitions that I have:
TeslaCam
Music
Boombox
Lightshow
Wraps
Getting Started
Image Requirements
    • exFAT
    • ext3
    • ext4
Troubleshooting
I do not see Paint Shop on my Toy Box.
cybergriz
Karl
Lancaster PA
Self employed
Guessing you need content and a partition for the paint shop to appear? Running 2024.39.5 and there's no paint shop in my toy box. I have not done any other steps.
No Paint Shop in Toy Box for me (2024.39.5). I do not know what firmware version the OP is using and they didn't say.
mikeg112
Bay Area, CA
Model Y, Cybertruck
I’m now wondering if this is in anticipation of the holiday update, we may have to wait until the next software release to get it, would be helpful if OP could post how they got the above images
The instructions fail to say what kind of USB to use. I used USB-A because that is what I have on all my flash drives, but most of the USB ports in the CT are USB-C.
I had no problem getting to the instructions and creating the image to their specifications. It was after I had created the 'Wraps' folder with the image in it that I failed when I took it to the CT.
rlhamil
Richard
Glen Burnie, Maryland
The USB-A in the glovebox is data. I think all the rest are just charging.
