Pops
Pops
Houston, TX
MY, CyberBeast
Interesting, your version is different than what I have. I wonder if some of the geometry is lost in the STL file? When I open the STL file it looks correct in my slicing app.
Yours vs mine:
Tesla Cybertruck [3D Print] Christmas - Rudolph Red Nose and Reindeer Antlers 1765747980171-61
Tesla Cybertruck [3D Print] Christmas - Rudolph Red Nose and Reindeer Antlers 1765748064806-oz
Loudness
Jay
Atlanta
Cybertruck (AWD)
Yours vs mine:
I picked mine up off of Etsy, it looks like it assembles the same using the little printed I-beam pieces, but yeah, the bases on mine are solid and tall.
Gaximus
Mead, CO
Software Developer
Here is how I recommend you assemble it.
Step 1 is assemble 1 side first with both dowels. You only need to glue the ends of the antlers that touch, the dowels dont need glue.
Step 2-4 is add the 3 remaining parts on to the first side, 1 piece at a time. Gluing all the sides that touch (sides and ends)
Pushing in the dowels is a bit tough, I was able to do it pressing together the parts resting on a towel for cushion. I do not recommend a vice grip, it will damage the antlers.
You're welcome to post the nose on MakerWorld.
I cannot post your Rudolf nose on MakerWorld because 'Share' is disabled and 'Remix' requires the existing model and you never posted the nose to MakerWorld. I would never take credit for someone else's creative work so I cannot post it there. Here is the revision. CTOC will not let me upload the .3mf file for some reason. All I did there was to reorient so that the mount is the base. That way I didn't need supports.
Loudness
Jay
Atlanta
Cybertruck (AWD)
and those magnets are strong enough for the weak magnetic effect of the stainless?
Yeah, no problems so far. I've been driving around with it for the last couple of days, it hasn't moved it all.
Gaximus
Mead, CO
Software Developer
Printed. Posted on a face book page. Will give credit to the designer if you want.
Tesla Cybertruck [3D Print] Christmas - Rudolph Red Nose and Reindeer Antlers IMG_0408
Tesla Cybertruck [3D Print] Christmas - Rudolph Red Nose and Reindeer Antlers IMG_0411
Pops
Pops
Houston, TX
MY, CyberBeast
Looks great! I had designed the nose to be lower and attached on top of the plastic bumper. It looks much better when attached to the front like that. I wouldn't recommend people do that to the raw SS. Every time I have used adhesives on the SS it left a residue that is extremely hard to remove.
Regarding the credit, that isn't needed, thanks for asking. I would just link them to the MarkersWorld files if anything.
cypherbeat
Ben
florida, USA
engineer
If you Could please link the nose to makerworld. I have tried with the .stl file and its not accepted on my bambu. It seems that its only .3mf files
Sdeland
Muchigan
Model S
There is no way in hell i am getting these dowels to fit in! 😂 What am I doing wrong? Do u think it converting the dimensions incorrectly?
What printer? I have a Bambulab H2S and the MakerWorld link Pops provided printed just fine.
Re the dowels, is it that you cannot get them in at all or you cannot get them in all the way to the bottom? I wasn’t able to get them all the way in but it wasn’t needed.
the problem I had is not knowing how much of the loctite to use, so I ended up using 2 tubes :)
Pops
Pops
Houston, TX
MY, CyberBeast
Sorry you are having trouble. They are wider than the hole, that's what gives them a tight fit. This might be a problem with the nozzle you are using and it isnt able to print at that detail level.
Here are the dimensions of the holes and the dowels in mm. You can try making a custom sized one to fit in your print. The difference in width of the dowel is only 0.1mm, thinner than a bee's dick.
Hole, 5mm wide.
Tesla Cybertruck [3D Print] Christmas - Rudolph Red Nose and Reindeer Antlers 1766384172621-yh
Dowel 5.1mm wide.
Tesla Cybertruck [3D Print] Christmas - Rudolph Red Nose and Reindeer Antlers 1766384451451-wk
