CYBERTRUCKco
Roger
Poway, CA
manufacturing
Guys and gals, happy Hump day! Just launched last night and sold out first batch to our local customers, next batch arriving in 4-5 weeks!
200w Solar hood panels - $699.95
This 200w panel set is a great way to integrate Solar panels into your Cybertruck to charge your portable power station(jackery, goal zero, etc) during daylight. OurKit is purpose-built to fit seamlessly on the hood giving you a fully integrated giving you ultra-efficient charging solution that looks OEM to keep your fridges, dash cam, lighting, phones, etc., charged without draining your vehicle battery.
NO - THIS WILL NOT CHARGE YOUR TRUCK!
Kit Includes:
  • 2 x 100W hood solar panel
  • 1 x vinyl hood decal
Flexible Solar Panel Benefits:
  • Keep your power station charged. The solar panel comes with standard connectors and uses adaptors (buy separately) to charge for most of the power stations on the market.
  • Decreased hood glare. The flexible solar panel features a top-tier ETFE film surface that eliminates light reflection, reducing glare while driving.
  • Convenience and space-saving. The hood flexible solar panel attaches directly to the vehicle’s hood; no roof rack is needed.
Flexible Solar Panel Features:
  • Solar cell: Grade A PERC Monocrystalline solar cells with much higher efficiency and more durability than other mono solar cells.
  • Premium EFTE Film: This film features superior light transmittance and weatherproof performance and is heat, corrosion, and UV resistant.
  • Durability: Cutting-edge tech and robust materials ensure resilience against snow, ice, mud, rocks, etc. Their high durability makes them perfect for off-road vehicles.
  • Ultrathin & Lightweight: At only 3mm/0.12 inches thick, it is lightweight (60% less than conventional solar panels).
Electrical Information:
  • Peak power: 200W
  • Solar cell efficiency: 25%
  • Maximum power voltage: 32V
  • Maximum power current: 4.25A
  • Open circuit voltage: 23.5V
  • Short circuit current: 4.6A
  • Power allowance range: +/-3%
  • Maximum system voltage: 500V
  • Net Weight: 5.5 lbs
  • J-Box: IP 68 rated with 1.5m/5ft cables
  • Values at standard test conditions: Air Mass – AM1.5, Irradiance – 1000W/m2, Cell Temperature – 25°C
Tesla Cybertruck 😎 New 200W Solar Hood Panel Launched by CYBERTRUCKco! cybertruck 200w solar hood panels-1
Tesla Cybertruck 😎 New 200W Solar Hood Panel Launched by CYBERTRUCKco! cybertruck 200w solar hood panels-2
The hood panel is in the same plane as the windshield. Because the drivers eyes are below that plane, the hood cannot reflect glare into the driver's eyes.
RoboTaxi
Kansas
Beast when the gods bless me
Raw stainless would reflect more then these, right?
Outdoors
Outdoors
North West Montana
This is a convenience item. Not everything in life has a payback. Some make life easier. So cost for these products is usually relevant for how much inconvenience it reduces rather than payback. In this case it charges a portable battery so one doesn't have to use the battery from the truck for other uses. Is it for everyone? Nope, but it beats setting up a panel array and putting a panel array away. I am sure Cybertruck Co is working on one for the camper top.
Great job @CYBERTRUCKco!
atk0506
Andrew
fort worth, TX
Cyberbeast, Model Y
Kit Includes:
  • Peak power: 200W
How is the durability again road debris?
Planet Earth
Novel idea with a reasonable price tag.
-Will this product trickle charge the HV battery to help eliminate vampire drain if parked in the sun?
-Projected lifespan of your product, including wiring cables subject to UV exposure?
-Will the frunk still lift with the added weight?
There is currently no official mechanism for a low/ medium voltage source to charge Cybertruck.
So here is what I envisioned. You put an Ecoflow delta 2 max in the back corner of the vault. Doesn’t occupy a lot of space and connects to the 800w Ecoflow alternator charger which acts as both a battery tender and input for the power station. It can manage either a 12v or 24v battery in either direction and has 1kw of solar input through two mppt’s.
then you get something like this and put it in the smugglers bay (slightly smaller or larger is minutia I think).
https://a.co/d/4hx39c6
Then you hook the alternator charger to that and connect let’s say 200w on the frunk as shown here and about 600w of panels elsewhere with some snazzy aerodynamically well thought out wire path.
any time you are driving or parked in the sun, you’re probably pulling 400w-600w off your 800w array.
when you fill up the 2kwh delta 2 max it fills up the 8 or so kWh battery under the vault using the alternator charger.
Then, when you are parked, you hook the mobile connector up from the delta 2 max to the car’s charge port. You can also mostly close the vault.
so….you are now getting the 400w-600w off the solar inputs to the delta 2 max but also the 800w from the alternator charger back into the power station. So you can charge at about 1.5kw for quite a few hours before the reserves are depleted.
over an extended period of time, that’s real charging. It means you don’t have to sweat being able to get home from your remote campsite. Also means you don’t have to sweat using electricity as you want at your campsite.
ABILISK
DFW
‘24 Beast
Maybe they mean the driver on the road in front of you ?‍♂?
Literally the first person on this entire thread to consider anyone but themselves. Including me. That’s hilarious.
Thanks Abilisk. That’s a pretty legit question.
Docedward
Nashville
Non-FS 2024 AWD
Ai
Gave it some thought. Asked Grok- and it’s got potential if it was wired to feed the truck. I’m not ready to 3M something that’s used 8 hours a day on good days to the drunk- but it does give it a bit more of that LA apocalypse look.
Conclusion(Grok)
The 200W solar panel on your Cybertruck’s trunk hood can generate about 800 Wh/day in sunny conditions, giving you ~2.2 miles of range per day (up to ~2.9 miles in ideal conditions, down to ~0.5 miles on cloudy days). This is useful for small top-ups, like offsetting idle losses or short commutes, but it’s not a primary charging solution. For more range (e.g., Musk’s 15 miles/day), you’d need a larger panel array, likely covering the full tonneau or adding fold-out panels, which isn’t what this 200W spec describes. Check your local sunlight conditions and driving habits to refine the estimate, and weigh the panel’s cost against its modest savings. If you want to explore a specific scenario (e.g., your city’s sunlight or driving patterns), let me know!
