Dazureus
- Sep 1, 2023
- US
- '21 Model Y, '24 Cyberbeast
- Occupation
- Software Engineer - Steering Systems
- Thread starter
- #1
I have a '16 Model X that has gone through a few half shaft warranty replacements and 3 sets of summer and 2 sets of winter tires. When I first purchased it, I drove at normal height with the automatic lowering set for highways speeds. The OEM tires didn't last a year with excessive wear on the insides tread of the rear tires. The camber difference from normal to low was enough to cause pretty bad tire wear (down to the belt before I realized it). As mentioned, I've had the half shafts replaced twice. The last time, Tesla suggested setting the suspension height to low all the time as it's probably the height that induces the least amount of angle between the motor and wheels. In the Model X, setting the suspension to High and Very High will automatically lower to Low after 100 ft. Setting to Medium and Low will remain in that position unless automatic lowering is enabled. Setting to Very Low will raise back to Low after driving is completed. I believe the Model X has about 2.7" of overall travel from Very Low to Very High. Newer vehicles have active dampening.
I guess my point of this thread is to gather thoughts and opinions on how excessive tire wear and half shaft wear may or may not be mitigated on the Cybertruck, considering it's larger range of adjustable suspension travel. From some settings screen shots, we've seen that there's a High, Medium, Low, and Entry height but pretty much everything is unknown right now. Do you think Tesla will carry over automatic lowering to Medium or Low after certain distances or, considering the truck target demographic, will they allow any ride height for any distance? Are we going to see excessive wear on tires due to negative camber at lower suspension settings? Are we going to see early half shaft replacements if we drive too much on High or Medium? Will there be active dampening? I'm not a suspension guy, so what are your thoughts?
