Anyone having challenges with their trailer and Cybertruck?
firstblackman
Eric
Atlanta
S, 3, X, Y, i3
The truck can see the trailer and even do the light check without issue.
It shows the blue trailer icon light.
The second I put the truck in drive it gives a fault error.
Tesla Cybertruck Anyone having challenges with their trailer and Cybertruck? tempImageLnSKYx
Tesla Cybertruck Anyone having challenges with their trailer and Cybertruck? tempImageW8LBl4
aeroguy
VA
Probably a long shot, but I'd check to see if the blue connector on the inside of the 7-pin connector is snapped all the way in. If you have long arms, you should be able to reach in and wiggle it. If that doesn't work, maybe check the resistance across each of the trailer pins to see if there is a short in the trailer wiring. Do you get a blue trailer mode icon on the dash prior to selecting drive?
https://www.cybertruckownersclub.co...trailer-connection-no-power.17402/post-321700
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
have you been able to verify that the trailer breaks are functioning correctly on another vehicle?
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
Does that trailer even have trailer brakes?
firstblackman
Eric
Atlanta
S, 3, X, Y, i3
Yes, the blue connection icon light comes on. I'll check the wires and grounding to confirm nothing is loose
firstblackman
Eric
Atlanta
S, 3, X, Y, i3
Yes, the trailer works without issue on my gas truck. No issues there
Grounding issues notoriously plague trailers. I think the manufacturers only hire incompetent drunkards for both assembly and testing.
tmeyer3
Trevor
www.meyerwine.com
Always good to do a sanity check... hmmm, I'll defer to better expertise on the forum. I've towed a few trailers with brakes so far and haven't had this come up.
firstblackman
Eric
Atlanta
S, 3, X, Y, i3
Thanks, I'll check and confirm the grounding on the trailer
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Try moving forward and hitting the trailer brake.
sefar
se
Missouri
Model S 100d, Cyberbeast FS
Church. I have wired and rewired my utility trailer multiple times, ground faults are a consistent problem and like all electrical issues they are notoriously hard to track down. I pull my tractor and UTV to the field where grass and brush plague me constantly.
