- Gus
- May 22, 2021
- Austin, TX
- 1981 DeLorean, 2024 Cybertruck
- Occupation
- IT Specialist
Source?Thats an off topic comment.
Yes it is. It is not lossless, but it loses less than regen which is actually pretty inefficient. It's not like using regen avoids all drag either. You can get an idea of how truly rolling efficient Tesla vehicles are if try out some coasting when it is too cold for regen.Sorry but it is not. Using regen captures energy and stores it in the battery. It also slows you down which means you are wasting less energy in drag.
Regen is the correct answer. Anybody thinking momentum or speed is lossless is incorrect. Google Drag vs Speed and you will see the difference.
Don't worry, I heard GM is working on. Their research program to harvest the hydrogen in the air and use braking energy to convert it to gasoline is running in parallel with their hydrogen vehicle development program. A win in either of these difficult potential fuel sources would vault them ahead of Tesla.No amount of braking will ever put a drop of gas back in your tank.
No, because sometimes you need to come to a stop more quickly than low regen is capable of. Friction braking is 100% loss.So we can set to Low Regen and get more range? ?
Hear me now and believe me later...Yes it is. It is not lossless, but it loses less than regen which is actually pretty inefficient. It's not like using regen avoids all drag either. You can get an idea of how truly rolling efficient Tesla vehicles are if try out some coasting when it is too cold for regen.
Actually, the answer is no, because tesla disabled the ability to turn off/reduce regen a couple of years agoNo, because sometimes you need to come to a stop more quickly than low regen is capable of. Friction braking is 100% loss.
I don't understand your "not regenerate". When I came back from Val Thorens in the Alps from the mountain to the valley (34 km) with my Y, I arrived in the valley with 36 kms more than I departed ?? Why should not regenerate help ?
No, itās doesnāt make a difference how much headwind you have. Coasting if FREE, so if you have a headwind you get less āfreeā but whatever you get is still FreeMy thoughts on possibly coming out ahead by not converting regen power and gaining speed, is that whatever you might gain by this, you're losing by having to increase your speed, and thus increasing wind resistance.
I hear you but what you say but it doesn't change the efficiency relationship between regen versus coasting. There is a formula to calculate the relationship between momentum and kinetic energy. Momentum seems to be the applicable term to use because in this case, in addition to mass and velocity, direction matters.V2
Momentum is not energy and it is not in the equation.
The critical components are:
Potential energy: Height x mass x g
Kinetic energy: 1/2 mv(2)
Drag force : The difference in drag at 50 kph and 100 kph
is 500%
Probably some other factors like rolling friction but who cares....
Yeah, the other factors that you don't mention are very significant, namely the fact that regen is lossy. It puts the aero drag to shame at most normal speeds.V2
is 500%
āCoastā method described by other posters in this thread is more efficient because of heat losses under acceleration and regen. So if you lose ~5% under throttle and lose ~5% under regen youāve lost 10% to heat/friction etc for the round trip of that energy. Thereās no such thing as a perpetual motion machine due to these losses. Compare that accel/regen calculation to coasting (0% energy used so zero lost).That can't be correct can it? Tesla has been doing EVs longer and better than anyone, having to manually use the "ole coast n save" manually can't be better than letting the Tesla engineering/software do it can it?
Maybe there is a bug in the software and that would explain the really bad range #s that we have been seeing?
Sorry youāre incorrect, and I suspect your error is assuming that regen energy = 100% recovered. Itās significantly lossy to covert kinetic to stored electricity.Sorry but it is not. Using regen captures energy and stores it in the battery. It also slows you down which means you are wasting less energy in drag.
Youāre both correct and incorrect on this one; in city driving @HaulingAss is correct. For freeway driving, @Eddyrelik ās query is the correct answer to better efficiency (but not necessarily stress-free driving!)No, because sometimes you need to come to a stop more quickly than low regen is capable of. Friction braking is 100% loss.
