Trekboy
- Mark
- Sep 1, 2023
- Redding, CA USA
- Tesla Model 3, Toyota 4Runner, Cybertruck
This would be a good thread for Elon to chime into....
Ok so you have the physics equations, now do the calculation for two scenarios:V2
Hear me now and believe me later...
Momentum is not energy and it is not in the equation.
The critical components are:
Potential energy: Height x mass x g
Kinetic energy: 1/2 mv(2)
Drag force : The difference in drag at 50 kph and 100 kph
is 500%
Probably some other factors like rolling friction but who cares....
Well played, sir…well playedDon't worry, I heard GM is working on. Their research program to harvest the hydrogen in the air and use braking energy to convert it to gasoline is running in parallel with their hydrogen vehicle development program. A win in either of these difficult potential fuel sources would vault them ahead of Tesla.
They are calling their program to synthesize gasoline from braking energy ultium braking (tm) and they claim, once developed, it could be applied to their entire lineup and even solar powered EVs will be equipped with gas collection tanks, so they can help fill-up the tanks of ICE vehicles, all powered by clean solar energy!
Mary is still leading the way!
I already provided the correct answer but I will elaborate:Has consensus been found on whether it is more optimal to keep small bit of regen going during downhills vs neutralize it?
My approach has always been to just have the slightest amount of regen going such that I can maintain my desired speed throughout the slope. Maintaining speed seems most efficient to me (albeit this is purely gut feeling/intuition).
Just like me learning to drive my Prius back in the day. Range is a function of your right foot. Watch the bars on the screen!Although I drove 65-70 on freeway and speed limit on streets, energy management is key. For example, on a long down hill I coast by not regenerating nor using any power. If you see the green bar, you are regenerating. Press the power pedal slightly to remove regen. If you see the gray power bar go up, you pressed too far and are now using power. Sometimes going faster downhill will increase range because you stop regen and coast as long as you stay within the speed limit. Of course if speed picks up too much you must lift and start regen. Understanding the energy management is key for long range. I call this the Scott Dixon approach, if you follow Indy Car racing you will understand.
I forgot there were people still worried about range, I thought this was an exercise in maximizing efficiency. Yes, for any given battery, efficiency affects range, but I haven't worried about not having enough range since I started driving a Tesla 6 years ago. Once I figured out how quickly a 15-minute driving break at a Supercharger made range a non-issue. Now I just hypermile for fun, when I feel like it.Just like me learning to drive my Prius back in the day. Range is a function of your right foot. Watch the bars on the screen!
Because Coasting is 100% efficient and regen is not. If you coast down a 10 mile downhill grade vs regen Your wh/m average will be less by coasting. You need regen to control speed but if you are going. 55mph with regen and can safety go 65mph by lightly pressing the Accelerator (until the green bar goes away but before the power is engaged) you will get better range by going faster. .Please explain why coasting downhill is better that regererating.
Can Tesla do a sw update to fix my right foot? Seems to be defective vs. range!Just like me learning to drive my Prius back in the day. Range is a function of your right foot. Watch the bars on the screen!
Tesla needs a SW update to include a “Coasting” feature.Can Tesla do a sw update to fix my right foot? Seems to be defective vs. range!
They will never do that. They used to have no regen and then low regen as options, and they removed them from newer vehicles. They have even removed "roll" from newer 3/Y vehicles. They will not add them back in now. Especially with the new EPA rules for measuring range. Only the worst mode will be used to do their calculation, and not having regen definitely hurts with the way the epa measures range.Tesla needs a SW update to include a “Coasting” feature.
Correct, but don't get enamored in the concept, because braking kill it.So NOT using "regen" increases efficiency?
Interesting, completely counterintuitive to what my impression was.
Maybe there is a issue with the CT regen that is causing the bad 450+ wh/mile numbers we are seeing with so many other vehicles?
It you stop moving, the car will go into "hold" not park.Afaik I know it won't go into park if you are moving unless you hold park for a few seconds, which would engage parking brake in a emergency if you lose your brakes
