Brake Malfunction; hit light pole
Aegeas
Washington
Cybertruck Cyberbeast
Given the location of the impact braking wasn’t your issue so much as steering to not hit the pole. It looks like you didn’t, or couldn’t steer to miss the pole. This feels like operator error but the onboard diagnostics will tell the tale.
MasonryGC
Don
Cybertruck/Benz/Harley/KeyWest
Masonry General Contractor
I hate when poles are in the middle of your lane!! Speeding around a curve can cause this as well with or without brakes
kdn
Ken
Cleveland Ohio
Maybe he thought he had FSD.
BannedByTMC
NYS
So I think it is quite reasonable to assume you invented the other "claims by some" as well. I have not seen anyone other than you suggest this.
You mean like the person you were replying to?
Assuming it was not false information posted by a Tesla short-seller it is a pretty serious issue.
TickTock
Phoenix, AZ
Electrical Engineer
He didn't make the claim you suggested either. You're extrapolation of both our posts is entirely made up. Show me where anyone other than you suggested "he bought a Cybertruck, crashed it, posted pictures here on this forum that few people even know about, to slow EV adoption? ". You combined two different rational scenarios (1) crashed his truck and wants to blame Tesla instead of taking responsibility for poor driving and 2) found/faked photos and created a BS post to spread FUD as he was paid to do) into one stupid scenario and tried to say that others were saying that. Even editing my post to eliminate the part that didn't fit your picture.
FutureTruck
GA- USA
Tesla MX P, Lucid Air GT
My guess is that the original poster will update us in the next week or so with the full story, if not it may have not been true.
HUM469
Dylan
Sacramento, CA
CT Dual motor one day (position 71k on res. #)
So I know exactly where this happened, and feel absolutely confident that this was driver error. I say this because I can count at least a dozen other times I've seen this exact same crash at this exact same spot. I also imagine that the fence was added by SMUD in the last year because I've also seen cars go over the little grassy hill twice and take out employee cars parked in the lot when they don't hit the pole prior to the fence being built.
The OP was coming over an offramp from the freeway and making a left. The light for the left isn't immediately visible when one comes off the freeway as there's a curve and a climb. Constantly, people try to shoot the light here when they see it is changing at the last second. But the ramp and the road don't meet at 90 degrees, meaning the turn is much tighter than most. And like all the roads around here, this intersection is long overdue for a repaving, meaning it is pretty slick.
The OP came off the freeway, saw the changing light late, goosed the go peddle to not miss the light, then hit the brakes late into the turn, after traction was already broken, forcing the ABS to try to do whatever it could, which given the weight and the non-standard turn angle, was not much.
For those asking about a diagram:
Tesla Cybertruck Brake Malfunction; hit light pole 1000005527
Incase anyone doubts I got the right intersection, note the building down the street:
Tesla Cybertruck Brake Malfunction; hit light pole 1000005525
It's nearly a 7000 lb truck, off angle, on all terrain tires, going over the rise of the central intersection on very old asphalt. It was never going to make the turn successfully at any speed above 20 mph or so. Depending on the entry speed of the truck, there might have been some limit to the steering angle too, thanks to the variable ratio. But without OP admitting to the actual speed he crossed in to the intersection at, we can never know that particular point with certainty. But being as this crash is common at this location, it's not at all surprising that a CT would have the same problem as every other vehicle pushed too fast into this corner.
Cboy7
Cboy
Was the black aluminum fence just installed this past year?
Edit: i think you are correct on the location and the posts on the black fence do look fresh
Speedr
Dual Motor Cybertruck
Wow! Great detective work! This explains all...
