- Oct 3, 2020
- Western Washington, USA
- #16
I haven't found the plastics to be a problem. They are really tough. Sure, they will get little micro scratches as dirt gets ground into them by branches, but they clean up nicely and don't really detract from the overall aesthetics. You can always polish those fine scratches out with fine sandpaper if you want. The kind of quality plastics used by many automakers tend to return to their original shape, most of them don't bend into new ugly shapes like metal might. I did back into a stout tree with the rear bumper once, and the corner of the bumper cover deformed, but 5 minutes with a heat gun and a tire iron straightened it right out.If only there were metal versions of all of the plastic parts on the truck!
But not all plastics (or metals) are created equal. Not far from where this bushthwacking video was taken, there was a 2018-2019 Ford F-250 Lariat Super-Duty parked at a trailhead. It looked like this truck was used in similar conditions:
It had thousands of dollars worth of aftermarket suspension modes, lift kit, 4-link front suspension (designed to make it stronger and maintain better steering geometry through the wheels travel), Fox shocks to replace the cheap OEM shocks, etc. But trucks like this are not as tough as their legacy manufacturers will have you believe.
A closer look reveals how the Cybertrucks plastic bumper cover is superior to the hybrid steel bumper with plastic step. This is a very cheaply made truck, and after a bit of rugged use it really shows.
But this is what I really wanted to show, the damage that happens to a Super-Duty truck doing the same kind of bushwacking that the Cybertruck handles with ease. The mirrors are not designed "Tesla tough" with the brittle plastic turn signal lens, the lower hinge fairing was broken (probably by a sapling or branch), the entire A-pillar is covered in dents from the same, and even the window frame has multiple dents. Notice how the shape of the mirror is not designed to part brush. It's almost as if they designed then to cause as much drag as possible. And it's hard to see in this picture but the arrow at the top is pointing to the roof trim that has been pulled loose.
Roof trim? Really? What were they thinking?
And you may notice, even with the lift kit and all the suspension mods, the differentials still hang precariously low, ready to disable the truck, or become high centered, due to a protruding rock. The Cybertruck has almost twice as much ground clearance as this lifted F-250. Sure, it's not designed as a rock crawler (obviously) but neither is the Cybertruck.
One vehicle is just a lot more capable than the other when the going gets tough. And it doesn't need thousands in aftermarket mods to fix it's OEM deficiencies. It's ready to go off the floor. Maybe get some tires that are better for off-road snow/mud. That's it. Honestly, the OEM AT tires will work great for most firm surfaces most people will encounter.
I see the plastics on the Cybertruck as being the most suitable material for the job. Tesla chose different kinds of plastic to best suit each application. Put metal fender flares, metal mirrors, and metal bumper covers on there at your own peril. I like that the plastic fenders will give a bit, rather than dent, if you kiss a tree or rock wall with them. Maybe a rock will even scratch or gouge them, the outcome would be worse with metal fenders.
