Charge Rate Limited by Charging Station - 35kw
noobla3
United States
CT
Unemployed
Is the Cybertruck asking for more power than the V3 station can provide?
on 3 occasions charging at a low SOC I’ve experienced ramping up to 250kw, but then immediately get this message and drops down to 35kw for a couple of minutes before slowly ramping back up to 250 and then down to 35.
Is there a bug or problem with my truck? I recall seeing a video about this issue but can’t find it and don’t know if this has been resolved?
Do I need to go to a V4 or what?
noobla3
United States
CT
Unemployed
I believe 35kw is the "limp mode" when the thermal sensors are reading bad/null data.
This has happened to 3 different V3 superchargers.
Where is this limp mode reading from? The supercharger or the car?
Yeah, usually means truck is asking for more than charger can provide.
Any old errors logged on the service menu?
noobla3
United States
CT
Unemployed
I didn’t check the error logs. Didn’t think it would be logged but will check next time I go to the truck.
This is the message that pops on the screen while charging.
Tesla Cybertruck Charge Rate Limited by Charging Station - 35kw IMG_2625
UberNoob
CyberBeast & M3P
Desktop Security Engineer
The supercharger can and will limit if the cables are faulty or the liquid cooling isnt functioning properly. All that juice warms them cables pretty quick. I’d try all the stalls then goto another station. There is a spot in the app to report your charging experience, under charging history.
noobla3
United States
CT
Unemployed
Did you see I mentioned it happened at 3 different superchargers? ?
UberNoob
CyberBeast & M3P
It was a bit vague, some call each post a supercharger, some call the station itsself the supercharger. My response was clairify stalls vs stations. If indeed you drove to the other side of town and that station was also doing it. Then I’d inspect your charge port for damage or gum / junk/ debris stuck inside . Otherwise it’s possible that site location is the issue
Especially if the posts all connected to the same cabinet.
Site level power limiting is a thing too.
#IWorkForGM
Detroit, MI
Cybertruck Cyberbeast
SWE
Hey! I've seen this before. Make a service ticket being very descriptive of the problem. This was what fixed it for me. If you venture into service mode you will probably also see some temperature sensor trouble codes.
Tesla Cybertruck Charge Rate Limited by Charging Station - 35kw 1000002193
noobla3
United States
CT
Unemployed
Thanks. This is very informative. I’ll check in a bit.
Did your truck also drop to 35kw when reaching near 250? It doesn’t happen when on a V2 site since it only goes to 150kw max.
noobla3
United States
CT
Unemployed
Gotcha. I meant 3 different sites.
#IWorkForGM
Detroit, MI
SWE
Yes, it only happened at high amperage. No problems when at 3rd party 350kW stations that support 1000v. The behavior for me was that it would happily do the 250kW for a while, then drop to 32kW-35kW, then go back up to normal speed after several minutes, then drop again, etc.
noobla3
United States
CT
Unemployed
Exactly my situation. Went into service mode and saw this error in log relating to HV battery:
Tesla Cybertruck Charge Rate Limited by Charging Station - 35kw IMG_2627
