Charging stops within a few minutes with wall connector
DrShah
Samir
Weston, FL
Surgeon
Hey guys this seems to be a new issue that just began. I have a non-foundation Cyberbeast and I have two Tesla Universal Connectors installed in my garage for our Model Y and CB. Today, regardless of which connector I used to charge the truck it will stop within a few minutes. They’re snuggly fit in like I’ve done countless times and they just stop within a few minutes. I have reboot the truck as well and same issue. Any recommendations?
I did updated to the latest software a few days ago. It’s not cold in South Florida compared to other places it’s 60° at night. I’m including the software version that I am running in the photo below. The Model Y with 105,000 miles is charging without any issue on both wall connectors.
Tesla Cybertruck Charging stops within a few minutes with wall connector IMG_2476
Tesla Cybertruck Charging stops within a few minutes with wall connector IMG_2475
Tesla Cybertruck Charging stops within a few minutes with wall connector IMG_2474
Tesla Cybertruck Charging stops within a few minutes with wall connector IMG_2473
DrShah
DrShah
Samir
Weston, FL
Surgeon
Are you getting any message from the app or on the trucks screen? Go into service mode and see if the log shows any issues.
just says connect charger again but it’s definitely inserted appropriately
furbyland
Lexington, KY
2023 Model S LR, 2024 CT AWD
I.T.
That sounds like a communication issue or negotiation issue between the truck and charger. I’d still recommend reviewing the service logs. They should with any issue log something.
RonM
Ronald
Palmetto Bay, Fl
2015 F150 CrewCab gone, 2024 Cybertruck DM dead, 2025 Cybertruck DM still here
Try a Tesla charging station, if that doesn't work..you got problems..
ldiebel
Lorne
Merritt Island, Florida
MX, CT-FS-AWD, CT-CB
Small Business Owner - Industrial I/O Networks
The voltage looks good on the screen shot (242 volts).
If the voltage dips for any reason, I think it will stop, but I would think it would show an appropriate error.
Does anything around the charger or connector feel excessively warm?
That's all I can think of.
Good luck!
DrShah
DrShah
Samir
Weston, FL
Surgeon
Good luck!
no heat but it worked ok when i tried the last time, i also didn’t close the garage on top of the cable which may have been the issue. I also charged at work and it was fine as well.
DrShah
DrShah
Samir
Weston, FL
Surgeon
I even have the Ting device which looks for any electrical anomalies in the home and no issues were noted even when both EVs were charging at the same time.
Humm, that would have been my guess given the behavior.
What does the vehicle display say when charging stops?
Have you tried a double scroll wheel reset?
Good luck!
That will reduce charge current, not terminate charging entirely.
DrShah
DrShah
Samir
Weston, FL
Surgeon
No error messages except connect cable. I did the double scroll reset As well, I went through the logs in the service menu and no abnormalities. If this keeps happening I will schedule a service appt.
Weird, blue charge indicator usually means scheduled charging...
I'm guessing you tried bumping up the charge limit to 85% or higher?
No 3rd party appzls linked to your truck?
DrShah
DrShah
Samir
Weston, FL
Surgeon
Nope nothing for scheduled charging. Also whenever I plug in at work, it begins to charge immediately.
