WHIZZARD OF OZ
Ivan
VW Up!
Electric Wheelchair Builder
They need a bolt in jump seat option for the vault with an intercom to the cab. For the bad kids.
Kids going to be 'BAD' just to ride in the Vault. Gaming in the Vault !!!
( Gonna be a THING )
firsttruck
mx
Ugh, the passthrough never made any engineering sense to begin with. The whole concept is silly, not because a passthrough is a bad idea, but because how the CT is designed. "vault" tonneau cover, or passthrough: pick 1. It makes no sense otherwise. Either you have a cover that rolls THROUGH where the pass through is supposed to be, or you have pass through that interrupts a rail system with a lot of moving parts. Both are very very bad ideas and I'm glad they didn't try it.
Tracks/Rails and pass-thru (gaps) are not inherently incompatible.
There are many bridges with pass-thru space between the bridge rails/sides and the ties/slats/planks. There are a lot of railroad bridges like this.
Just make sure to NOT occupy the passthru opening at same time the rail/track is also trying to occupy the same space.
Tesla Cybertruck Confirmed Cybertruck specs: 5% smaller, 6x4 bed size, 5 seats, frunk, no pass through & more... (info from Tesla employee at Investor Day) 1677822605670
Walking the Goldstream Trestle
Dec 26, 2015
Chris Birkett
Swinging and Swaying on the Hussaini Bridge ** Has more empty space than slats
The Hussaini Bridge in Pakistan's Gojal region is either a spectacular thrill, or a terrifying no-no. Unless you're a local - then it's probably just the way to work.
Oct 8, 2017
UrbanDuniya
12 Most Terrifying Bridges You Don't Want To Cross
Some people have always been frightened of bridges. Gephyrophobia sufferers often try to avoid crossing bridges altogether, driving miles out of their way to avoid them. Of course, quite a few bridges can be rough experiences for those with acrophobia, as well. With some bridges, however, terror seems to be the only sensible response. Here, we look at 12 bridges that would turn anyone’s legs to jelly. Read on, but don’t look down.
Jan 6, 2019
Mind Boggler
*** the following bridges in video have significant openings between ties/slats/planks or use glass for slats/planks.
01:40 Royal Gorge Bridge, USA * occasionally they allow cars to drive across despite the gaps
03:42 Puente de Ojuela, Mexico
05:37 Coiling Dragan Path, China
07:48 Kuandinsky Bridge, Russia
06:26 Q'eswachaka bridge, Peru
09:20 Hongyagu Bridge, China
10:40 Hussaini Hanging Bridge, Pakistan ** more empty space than slats
11:39 IYA Kazurabashi Bridge, Japan
@markbloomfield (2020) A couple months ago I ran a cross country race that ended on the far side of #11, the Royal Gorge Bridge. The last quarter mile was across the bridge, and I can confirm the whole thing shakes when people are on it, and it has lots of gaps an inch or two wide. There were several people who would have placed high in the race but refused to cross it. It definitely was one of the most memorable race finishes.
@user-rm2uv4jc2m @user-rm2uv4jc2m (2021) I’ve been to the royal gorge and you can literally see through the gaps in the wooden planks and it’s very scary!!
@TotallyLA @TotallyLA (2021) I've crossed the Royal Gorge bridge. I could see through the slats to the ground and it swayed badly. I was almost too afraid to cross it again to get back.
Unfortunately, some people traumatized their dogs by making them walk on see-through glass bridge.
Only one dog willingly walked across (was this dog stupid or blind!!!)
The bridge owners do have a way to get revenge on some dog owners.
This glass bridge will give you nightmares
May 21, 2021
Trend Spot
Some specs for y'all! (From the employee standing there with the truck at Investor Day.)
  • 6x4 bed size
  • 5 seats instead of 6.
  • Can't fit 6 with the shrink that happened.
  • 5% stated.
  • No pass through.
  • Will have a frunk.
  • Multiple tire options.
  • 18's on display truck
  • Waiting on length overall
An employee named Elon Musk or I don’t believe it (and why would you?).
At the end of the day you (all) have to make a decision: you believe what Elon has told us and Tesla has published (that is, everything) or you believe nothing they have told us or published and you can think whatever you want. If the latter why even have a forum? If the former why do you keep up with these shenanigans?
Even if they make changes, and they have, it has to come from an authenticated source.
TheLastStarfighter
Industrial Engineer
The original CT had a bed with of 57". If the width of the vehicle was reduced 2", we're at 55". To my eye, the 4-wheel steering wells now cut into the bed around 2-3" per side. This would make the bed around 50" at the base (a little wider at the top). For reference, an F-150 bed is 51", and so is the Rivian. So all in the same ballpark. If the vehicle length also shrunk in she same way, the 6'5" bed is probably now around 6'2"-3". 6X4 a fair approximation, but it's probably a little bigger and similar to other trucks. You couldn't put 4' drywall in a 4' gap; it needs to have wiggle room.
I’m fine with all of the above. This is going to be a great vehicle.
I’d be fine with any/all of these; I just don’t believe it unless it comes from an authoritative source. Meaning Elon says it or Tesla publishes it.
well, I want to see someone clean the windshield from the inside....looks like it about 4 feet and I dont have long arms.....I am just afraid there is going to be many thing that just don't add up to $80-85k....
I have been thinking about how to wash the windshield for a while now and have no solution yet.
EV Rob
Rob
Ventura, CA
Tesla Model S, Y
Also some sheet goods (e.g. melamine) come oversized at 49"x97". Agree wiggle room is needed, so 50" is minimum practical bed width, and 75" length would work. And we used to call the company work trucks "six packs" because they carried "six pax" to the job. That's six adult construction workers, not Mom, Dad and four kids. Add AWD, stainless durability, low maintenance, frunk/sail tool storage and power tool outlets and you have major competitive advantage. Tesla wouldn't make the bed and cabin just a few inches too small and miss that huge market.
happy intruder
O. K.
Irvine
wanna bet?
firsttruck
mx
Yup, for lack of a couple of inches and a seating position (#6), fall off the demand curve.
Trends from pickup trucks' Big Three
Ford's F-Series full-size pickups are the top truck by unit volume for the 46th consecutive year.
Jan. 13, 2023
By Kevin Jones reporting for Fleet Owner, Inc
https://www.fleetowner.com/equipment/article/21257578/pickup-trends
These Are the Best-Selling Cars (& pickups) in America in 2022
Cars is more of a catchall term, because full-size pickup trucks take the three top spots. U.S.A! U.S.A!
By José Rodríguez Jr.
Published July 12, 2022
https://jalopnik.com/these-are-the-best-selling-cars-in-america-in-2022-1849167025
How do Canadians stack midsize pickup versus full-size truck sales?
We break down the country's truck segment story, automaker by automaker, comparing small versus big
By Timothy Cain, Published Nov 18, 2019
https://driving.ca/features/feature...k-midsize-pickup-versus-full-size-truck-sales
Yet even with this recent growth, midsize trucks own just 10 per cent of the overall pickup market.
I’m acquaintances with someone formerly in the C-Suite at Tesla. And while I would never press, there have been glances and once a vague comment on how “that thing [the CT] is a problem.”
I don’t put a ton of weight on that, having enough experience inside big companies to know that most things worth doing are a sh*tshow up until they’re not.
But it does point to a possible reality where, faced with enough friction, compromises were made. Perhaps that turns out to not be true, and Tesla keeps up its perfect record (?) of delivering on specs. But if some compromises turn out to be true, I don’t think we should find it so remarkable or blameworthy that even Tesla might be mortal at times. Least of all when trying to deliver something as challenging (from an engineering perspective) as a BEV truck made of stainless with 500 mile range.
In that scenario, else was Tesla going to do: never produce the thing?
Which again re-raises for me a possibility regarding reasons behind a possible reduction in size: they equate to reductions in both mass (the crux of rolling resistance) as well as frontal plane (the crux of drag).
If on official release Elon says, “and one more thing, range is 650 miles” that may be reason to offset a lot of market “costs” in the size reduction.
AlDente
Roberto
Retired (of a fashion)
Lack of 6th seat, might be a deal breaker. Not all families have 2 kids, was hoping this could function as family vehicle.
Yeah, how could mister 10 kids be so inconsiderate ... Sorry Timmy, Mr Musk decided families need to be capped at 5.
With the current bed size, is it still large enough for 8 tires?
the tires in back of that proto look similar (not identical) to the tires on the investor day truck - which are known to be 285s, or 11.2” wide
Those tires DO look identical to the tires on the Franz photo’s truck of the same day.
In any event, if in that photo they are also 285s (4X11.2= ~45”) and if the purported 4’ bed width (46”) is correct: maybe?
In fact, that kind of tight fit might explain how/why the photo’s tires are seemingly standing on their own without being up against the bed rails - the bottoms are wedged snuggly between the narrower wheel wells
happy intruder
O. K.
Irvine
I am sure there will be some changes / deletions and addition of things that will have people liking or dis-liking them....but, as some have said, "Tesla tries to keep production equal to what was revealed, but who knows........everyone's taste is not the same......a 6-foot+ bed to me is mandatory....for camping with no pass thru, one may have to purchase the camping module....I don't like sleeping in a colder-off cocoon like box with no light or air exchange.....
but who knows, we'll just have to wait and see....and all the hoopla will come out in the end.......500 mile range is beginning to seem far away except for the most expensive optioned CT
